Hello fellow electronics engineers!
I'm having a bit of a problem with setting up the STM32F072-Nucleo board as a small shell (I want to send commands via UART and set/get various settings of the application I'm making.) using the UART with DMA in interrupt mode.
The code is based on BrinirController. The problem is that while I can receive the first character and echo it back, after that first interrupt the MCU does not do another interrupt if I try to write another character. The HAL I'm using is 1.2.1 (together with the STM32CubeMX) and it does not have the macro __HAL_UART_FLUSH_DRREGISTER(&huart2) for flushing the UART's RX data buffer.
Does the function __HAL_UART_SEND_REQ(&huart2, UART_RXDATA_FLUSH_REQUEST) do the same thing as the macro __HAL_UART_FLUSH_DRREGISTER(&huart2) in the previous version of HAL?
Could this be the problem: the RX data buffer is full so it just won't start another interrupt while it's not cleared/read from?
The RxCpltCallback callback function is called only the first time I enter something in the serial terminal... It just won't interrupt the second time... I've tried everything, it seems! :D What could be the solution? I'm using the STM32F072RBT6 (STM32F072-Nucleo board)
The code goes like this:
UART_HandleTypeDef huart2;
DMA_HandleTypeDef hdma_usart2_rx;
DMA_HandleTypeDef hdma_usart2_tx;
/* USART2 init function */
void MX_USART2_UART_Init(void)
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 9600;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  huart2.Init.StopBits = UART_STOPBITS_1;
  huart2.Init.Parity = UART_PARITY_NONE;
  huart2.Init.Mode = UART_MODE_TX_RX;
  huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  huart2.Init.OneBitSampling = UART_ONEBIT_SAMPLING_DISABLED ;
  huart2.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  HAL_UART_Init(&huart2);
void HAL_UART_MspInit(UART_HandleTypeDef* huart)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(huart->Instance==USART2)
  /* USER CODE BEGIN USART2_MspInit 0 */
  /* USER CODE END USART2_MspInit 0 */
    /* Peripheral clock enable */
    __USART2_CLK_ENABLE();
    /**USART2 GPIO Configuration
    PA2     ------> USART2_TX
    PA3     ------> USART2_RX
    GPIO_InitStruct.Pin = GPIO_PIN_2;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
    GPIO_InitStruct.Speed = GPIO_SPEED_LOW;
    GPIO_InitStruct.Alternate = GPIO_AF1_USART2;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_3;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    /* Peripheral DMA init*/
    hdma_usart2_rx.Instance = DMA1_Channel5;
    hdma_usart2_rx.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_usart2_rx.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_usart2_rx.Init.MemInc = DMA_MINC_ENABLE;
    hdma_usart2_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
    hdma_usart2_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
    hdma_usart2_rx.Init.Mode = DMA_NORMAL;
    hdma_usart2_rx.Init.Priority = DMA_PRIORITY_MEDIUM;
    HAL_DMA_Init(&hdma_usart2_rx);
    __HAL_LINKDMA(huart,hdmarx,hdma_usart2_rx);
    hdma_usart2_tx.Instance = DMA1_Channel4;
    hdma_usart2_tx.Init.Direction = DMA_MEMORY_TO_PERIPH;
    hdma_usart2_tx.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_usart2_tx.Init.MemInc = DMA_MINC_ENABLE;
    hdma_usart2_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
    hdma_usart2_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
    hdma_usart2_tx.Init.Mode = DMA_NORMAL;
    hdma_usart2_tx.Init.Priority = DMA_PRIORITY_LOW;
    HAL_DMA_Init(&hdma_usart2_tx);
    __HAL_LINKDMA(huart,hdmatx,hdma_usart2_tx);
  /* USER CODE BEGIN USART2_MspInit 1 */
  /* USER CODE END USART2_MspInit 1 */
and the interrupt callback function:
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
  __HAL_UART_SEND_REQ(&huart2, UART_RXDATA_FLUSH_REQUEST); // Clear the buffer to prevent overrun
  int i = 0;
  HAL_UART_Transmit_DMA(&huart2, (uint8_t *)&rxBuffer, 1);
  if (rxBuffer == 8 || rxBuffer == 127) // If Backspace or del
      printf(" \b"); // "\b space \b" clears the terminal character. Remember we just echoced a \b so don't need another one here, just space and \b
      rxindex--;
      if (rxindex < 0) rxindex = 0;
  else if (rxBuffer == '\n' || rxBuffer == '\r') // If Enter
      executeSerialCommand(rxString);
      rxString[rxindex] = 0;
      rxindex = 0;
      for (i = 0; i < MAXSTRING; i++) rxString[i] = 0; // Clear the string buffer
  else
      rxString[rxindex] = rxBuffer; // Add that character to the string
      rxindex++;
      if (rxindex > MAXSTRING) // User typing too much, we can't have commands that big
      rxindex = 0;
      printf("\r\nKonsole> ");
Of course, I'm calling the HAL_UART_Receive_DMA(&huart2, &rxBuffer, 1) in the main routine before the infinite loop and have defined these variables as buffers:
uint8_t rxBuffer = '\000';
uint8_t rxString[MAXSTRING];
int rxindex = 0;
Switch the RX DMA mode to DMA_CIRCULAR. Normal DMA mode executes once and you have to configure it again. Circular mode allows you to do the same operation until you explicitly stop it.
  • \$\begingroup\$ I had similar case, and switching the USART RX DMA Mode (within Cube's DMA configuration window) from to NORMAL to CIRCULAR has helped -> now ISRs for characters/data being received are being called regularly and do not require re-enabling them (which just means they work more stable). Thank you for the hint ! :-) \$\endgroup\$
    – user126563
    Oct 13, 2016 at 15:56
