In the following circuit assuming that diode's cutoff voltage is \$0.7 V \$ , I want to find operating points (voltage, current) of diodes \$D_1,D_2\$.
My first guess is that DI=0FF and D2=ON. Then I will have:
By applying KVL I have $$10V +I5kΩ -0.7V + I10KΩ +10 = 0$$ By solving with respect to \$I\$ we see that \$I=1.29mA\$
From this point how can I continue to find the operational points of the diodes???
------------------------------------EDITED_1---------------------------------------
My question was answered as you can see below it appears my first assumption was wrong.
My second guess is that \$D_1\$ is on and \$D_2\$ is off;
Then I have the following circuit:
By applying KVL I have $$-10V +I5kΩ +0.7V = 0$$ By solving with respect to \$I\$ we see that \$I=1.86mA\$
Then I will have:
\$V_{anode,d1}=0\$
\$V_{cathode,d1}=-10+IR1=-0.7 V\$
Where \$V_{cathode,d1}\$ is the voltage of node between the two diodes.
So now the main question, do these values hold true for our assumptions.
For D2 to be off, VD2<0.7 and \$V_{D2}=10V-I10KΩ-V_{cathode,d1}=10-18-(-0.7)=-7.3V\$
For D1, to be on VD1>=0.7 and \$V_{D1}=0−(−0.7)=0.7V\$
The math confirm our assumption So D1 is on and D2 is off!
------------------------------------EDITED_2---------------------------------------
As I was told my second guess was also wrong since there was a mistake in the math of D2. D2 is assumed to be off so there is no current flowing through it and hence there is no current flowing through R2 and hence there is no voltage drop in the anode of D2. In the second guess \$V_{D2}=10V-V_{cathode,d1}=10-(-0.7)=10.7 > 0.7V when it was supposed to be <0.7\$ So I am going to make a third guess.
My third guess will be that D1=ON and D2=ON
Then my circuit will be:
Then I apply Mesh current method to find I1 and I2:
$$I_1: 10V +I_15kΩ -0.7V = 0 => I_1=1.86mA$$
$$I_2: 0.7V -0.7V +I_210kΩ +10V = 0 => I_2=1mA$$
For D2 to be on, VD2>=0.7 and \$V_{D2}=10V-I_210KΩ-V_{cathode,d1}=10-10-(-0.7)=0.7\$
For D1, to be on VD1>=0.7 and \$V_{D1}=-10+5KΩI_1=0.7V\$
The math confirm our assumption So D1 is on and D2 is on! So probably the third guess was right!!
