I'm looking to model a repeating sinc pulse in LTSPICE, however I can only get it to fire once. I'm looking to delay it by x many ms, and trigger the pulse the again.
Is this possible with LTSPICE ?
  • \$\begingroup\$ you mean sin(x)/x? What are you using for the pulse? \$\endgroup\$ – Spehro Pefhany May 31 '15 at 23:23
  • \$\begingroup\$ @SpehroPefhany ya sin(x)/x, I'm using a behavioral voltage source (BV) \$\endgroup\$ – efox29 May 31 '15 at 23:23
  • \$\begingroup\$ A simple sin wave voltage source and a comparator would be my first approximation... \$\endgroup\$ – Spoon Jun 1 '15 at 7:42
  • \$\begingroup\$ @Spoon elaborate ? \$\endgroup\$ – efox29 Jun 1 '15 at 8:40
  • \$\begingroup\$ @efox29, do you just want a repeating pulse? I know it may seem silly but the Voltage source with Pulse and the following parameters as an example... PULSE(0 1 0 0 0 0.01 0.1) or a pulse you can adjust to test the sync function of your circuit? \$\endgroup\$ – Spoon Jun 1 '15 at 12:04
Just similar to what I wrote in this answer you can do almost anything repetitive by using the time variable and a modulus. So let us set this up step by step. First just a sinc function for convenience:
.function sinc(x) { sin(x)/x }
Using this together with the time variable and a little scaling we can get this b source:
V=sinc(time*100)
to produce this here:
This isn't repetetive so let us create a modulo function and use that to bring back the parameter into range:
.function mod(x,y) { (x/y)-int(x/y) }
V=sinc(mod(time,1)*100)
Better, but not quite nice as the "pulse" starts at 0 of the sinc again. It would be better if it started a bit lower, so lets shift and align it a little bit nicer:
V=sinc(mod(time,pi/3)*100-pi)
You should now be able to take this as a starting point to calculate a waveform that matches your needs.
  • \$\begingroup\$ oh.. em.. gee :o \$\endgroup\$ – efox29 Jun 1 '15 at 9:21
  • \$\begingroup\$ perhaps you would want to shift the basic sinc left more \$\endgroup\$ – Mike Jun 1 '15 at 10:04
    \$\begingroup\$ @Mike: maybe. This is just showing how to do it, the exact amount of shifting and scaling is up to whatever the OP wants in detail. \$\endgroup\$ – PlasmaHH Jun 1 '15 at 10:09
I'm not sure if this is helpful in the context of your simulation, but you can produce an approximation to a series of sinc pulses with a slight negative DC bias by simply summing together a set of cosine waves. Start with one at the pulse repetition frequency, and add integer harmonics of that frequency, all at the same amplitude:
$$pulse(t) = \sum_{i=1}^N cos (2\pi i f t)$$
The value you select for N will determine the width of the individual pulses; a higher value will create narrower pulses. Also, as N increases, the peak amplitude of the pulses increases linearly as well; scale by \$\frac{1}{N}\$ if desired.
See an example on Wolfram Alpha
  • \$\begingroup\$ You know, it's not the ideal approach because LTSPICE doesn't have a way to sum up multiple terms, but that Wolfram link pointed me in the write direction, that I can just write a macro that will create as many terms as I need and delay it by the value I want. It's a bit more work, but it beats typing out the series with a + in between each term. \$\endgroup\$ – efox29 Jun 1 '15 at 0:28
