I'm trying to set bit 2 in TIMSK register and using the following C code:
TIMSK |= (1<<2);
Compiler makes the following code:
TIMSK |= (1<<TOIE1);
108:    89 b7           in  r24, 0x39   ; 57
10a:    84 60           ori r24, 0x04   ; 4
10c:    89 bf           out 0x39, r24   ; 57
So it is Read-Modify-Write operation which is a) slow, b) not very consistent as sometimes it is better not to disturb any excess bits.
However if I'd replace TIMSK with let's say PORTA I will get SEI as expected:
PORTA |= (1<<2);
108:    da 9a           sbi 0x1b, 2 ; 27
So how do I force the compiler to compile the instruction above as bit instruction instead of RMW?
Or this (TIMSK) register is not bit accessible?
    \$\begingroup\$ The resulting code is not disturbing any excess bits. It reads the register, performs the OR and writes the result, it's exactly the OR-IS you typed in C code. Further, SEI is the global interrupt enable instruction (brother of CLI), you mean SBI as in your second code block. \$\endgroup\$
    – Asmyldof
    Jun 1, 2015 at 12:43
I found it:
Citation from original datasheet (page 20):
I/O Registers within the address range 0x00 - 0x1F are directly bit-accessible using the SBI and CBI instructions
So only first 32 registers are bit-accessible. TIMSK has address 0x39 - so it's pretty high above the range :(
  • \$\begingroup\$ Exactly. It's a trade-off for the choices they made way back when to keep things stream-lined in most-use situations. They do try to get the most likely candidates into the lower 32, though. How often do you write TIMSK? How often PortA/B/C? \$\endgroup\$
    – Asmyldof
    Jun 1, 2015 at 12:45
