I'm building a ac motor starter with a optocoupler (FOD4218) and a TRIAC (BTA16), one for each phase in a three phase 400V system. I have a question regarding the circuits that can be found all over the web, like this one: circuit http://www.electronics-tutorials.ws/articles/opto6.gif?81223b
What is really the purpose of the 100R resistor? Is it for voltage dividing or what? In my case where the circuit is between two phases, is it necessary? Some circuits do not have that resistor at all. I have planned to use 600R for the upper resistor.
Thanks.
The 100\$\Omega\$ resistor may help prevent the triac from triggering with high dv/dt (for example, with a somewhat inductive load- which you have with a motor load). It's generally not necessary unless you are using a sensitive-gate triac. For motor loads you should consider using an alternistor (Edit: which the BTA16 is), which has higher dv/dt immunity.
You did not ask about the 600\$\Omega\$ resistor, but increasing that part value from the minimum will cause unnecessary EMI and possibly other problems.
  • \$\begingroup\$ Thanks for your reply. I'm using the circuit suggested in the datasheet for the FOD 4218 link It uses a 360R resistor for 240Vrms, so 400V/360R = 1.1A. Following that, with two phases at peak 400V*1.141, 565V/600R = 0.94A, maybe 500R would be a better choice? The same circuit uses a 330R resistor, any idea how they arrived at that value? I'm using the snubberless BTA16, although I will have a snubber network to start with. Your help is appreciated. \$\endgroup\$ – Ma Sa Jun 1 '15 at 15:20
  • \$\begingroup\$ Given the voltage difference, 510R is probably fine. Preferably use a fusible part here with a high pulse capability, for reliability/safety. It can see 600W briefly if you switch at the peak of the AC line. If the triac fails to trigger, it will see most of the line voltage and rapidly fry. \$\endgroup\$ – Spehro Pefhany Jun 1 '15 at 15:48
