Consider the following state diagram where the inputs are c
and v
. The system is also receiving a high frequency clock clk
, about 50 MHz.
As depicted in the diagram, the first input is used for right-advancing the states and the second input is for left-advancing the states. In the hardware implementation (Altera DE1) these inputs are buttons.
The problem is, since the clock frequency is very high (relative to the button-press duration), when the c
button is pressed, it falls through to the last state S3
. Then if the v
button is pressed, it again goes up through the initial state S0
. The intermediate states S1
and S2
are only very briefly visited. The figure below illustrates the situation.
Here is the my VHDL code to implement the state machine.
First code. It works but the state falls through.
Library IEEE;
Use IEEE.std_logic_1164.all;
Entity state_machine is
port (
clk, c, v : in std_logic;
outp : out std_logic_vector(1 downto 0)
end state_machine;
Architecture beh of state_machine is
type state_type is (S0, S1, S2, S3); -- there are four states
signal current_state : state_type := S0 ;
Begin
Process(clk)
Begin
if (clk'event and clk = '1' ) then
case current_state is
when S0 =>
if c = '1' then
current_state <= S1;
end if;
when S1 =>
if c = '1' then
current_state <= S2;
elsif v = '1' then
current_state <= S0;
end if;
when S2 =>
if c = '1' then
current_state <= S3;
elsif v = '1' then
end if;
when S3 =>
if v = '1' then
end if;
End case;
End if;
End Process;
With current_state select
outp <= "00" when S0,
"01" when S1,
"10" when S2,
"11" when S3;
End beh;
In an experiment I slowered the clock down to 2 Hz. It works as the state diagram above intended, but it's not very reliable. Sometimes it advances one state, sometimes it "misses" the clock, sometimes it advances two states. Surely this is not acceptable.
I also tried to separate the clock and the state machine logic, in the following code.
Second code. It compiles but the output is undefined.
Library IEEE;
Entity state_machine_2 is
port (
end state_machine_2;
Architecture beh of state_machine_2 is
signal next_state : state_type := S0 ;
Begin
Process(clk)
Begin
current_state <= next_state ;
end if;
End Process;
Process(c, v)
Begin
Case current_state is
when S0 =>
if c = '1' then
next_state <= S1;
end if;
when S1 =>
if c = '1' then
next_state <= S2;
elsif v = '1' then
next_state <= S0;
end if;
when S2 =>
if c = '1' then
next_state <= S3;
elsif v = '1' then
next_state <= S1;
end if;
when S3 =>
if v = '1' then
next_state <= S2;
end if;
End case;
End Process;
"01" when S1,
"10" when S2,
"11" when S3;
End beh;
The above code compiles, but the resulting output is undefined.
My question.
How to implement the state diagram above in VHDL and it would work as one would expect? That is, one presses c
one time and it would simply advance one state only.
Perhaps I should not be using the clock in the FSM altogether? Or there is a better strategy?
sig_re <= not sig_d and sig;
(re = rising edge ). You can include it into the FSM by asking for that complete condition or you can calculate that outside of your FSM process, what gives a cleaner solution. You can now usec_re
andv_re
as a direct FSM input without worring for fallthrought. If you add a pin synchronization and debounce circuit to your design, you can decide to output only edge detected button signals that can be used in your FSMs directly. \$\endgroup\$ – Paebbels Jun 2 '15 at 6:49
