Modules of 3 LED
Simple LED strips or bars that are using 12V input voltage often have the following layout:
They consist of modules with 3 LED each, all connected in parallel to the input voltage.
A single module consists of three LED and one resistor in series with the input voltage.
(This answer has an example picture and schematic: Cuttable 12V LED strip)
High resistance after one LED breaks
The whole module goes dark, and all other LEDs get a tiny bit brighter because they no longer share the power supply and it's connections resistance with the broken module.
The secondary damage here is that more LED stay dark than are actually broken.
Low resistance after one LED breaks
Then, one module consists of only two LED and the standard resistor, which is now way to small for limiting the current in the normal way. So the two other LED in the module ret much more current, and are possibly much brighter. The other modules should get a little darker, because they need to share the power supply with the broken module, which now uses more current.
The secondary damage here is that the two LED which get higher current will break soon too. In the end, more LED will stay dark than were actually broken - because they broke too, in this case.
Workarounds?
Of course, in both cases, repairing would mean replacing the broken LED.
But what do to best, in each case, if no replacement LED is at hand?
  • \$\begingroup\$ Detect the fault and shut down the bar and associated driver. \$\endgroup\$ Commented Jun 4, 2015 at 1:15
It is best to feed the string which in your case has normaly 3 leds in series with a current source this stops led current rising steeply with increasing supply volts and stops current falling significantly unless supply volts go below about 10 which is unlikely NOW you can safely place a zener across each LED which is just above the max LED forward volts Example 3V9 for white led This is all cheap because the current source could be a two terminal IC or discrete transistor circuit and the zener doesn't have to be high power In fact all parts can be SMD so parts count isn't a penalty
  • \$\begingroup\$ If I can not change the power supply - should I still add zener diodes across some of the LEDs? Only the ones that get too much current? \$\endgroup\$ Commented Jun 4, 2015 at 2:21
  • \$\begingroup\$ Yes Volker you should do the Zener across the Leds. \$\endgroup\$
    – Autistic
    Commented Sep 28, 2015 at 19:55
