I repair intelligent lighting fixtures. These devices have a large number of motors, and so they also have a large number of motor drivers. It's not uncommon to have a single PCB with more than a dozen individual motor drivers mounted. A common issue with a particular series of fixtures is a driver failing in such a way that the 24V motor supply rail is shorted to ground. (Here's the datasheet for the driver in question)
My question: How can I identify which driver has failed, without desoldering multiple drivers until the short goes away?
Put 2A, maybe 3A on the rail and carefully touch them one by one. The failed will be hot.
  • \$\begingroup\$ I had considered this and tossed it aside, but I guess I wasn't thinking about my benchtop power supply. Looks like there might be two shorted. Thanks for the input! \$\endgroup\$ – Derek Jun 5 '15 at 16:59
In general, the old practical (but no as "pretty" as desoldering one by one) method to find a short inside one of a bunch of ICs with common supply is to burn it! It's not a joke - simply you need a laboratory power supply with proper voltage (24V in that case) and a few amps current capability with regulation. Connect power supply to 24V rail, set 24V voltage as maximum and slowly increase current from 0 to the moment when You can see a smoke or other interesting heat-related phenomenon on one of the ICs and, voilà, this is the bad one. Sometimes it is enough to pass a few miliamps and the bad one should be hot, test it with finger (don't do this at home!) or infrared thermometer.
