I came across a solved exercise regarding Signals and Systems in which there is a system with impulse response \$h(n)=u(n)\$ and input \$x(n)=u(n)\$. The goal was to find the output of that system (unit step response).
(Note that \$u(n)\$ is the unit step)
So the solution begins saying that the output is the convolution between the input and the impulse response which is:
$$y(n)=x(n)\ast h(n)=\sum_{m=-\infty}^{\infty}x(m)\cdot h(n-m)=\sum_{m=0}^{n}1=n+1$$
After that the solution concludes that the output is:
$$y(n)=(n+1)\cdot u(n)$$
Everything is really elementary and I probably miss something here but how does the term \$u(n)\$ appeared in the output? Wasn't proved that the output is \$n+1\$?
Exectly the same happens in another one concerning a system with \$x(n)=h(n)=a^{n} \cdot u(n)\$ where although \$y(n)=a^{n}\cdot (n+1)\$ the result eventually is said to be \$y(n)=a^{n}\cdot (n+1)\cdot u(n)\$.
When they say:
$$y(n)=x(n)\ast h(n)=\sum_{m=-\infty}^{\infty}x(m)\cdot h(n-m)$$
they are correct, but in the next passage they oversimplify a bit.
Let's do it step by step:
\begin{align*} &\sum_{m=-\infty}^{\infty}x(m)\cdot h(n-m) = \sum_{m=-\infty}^{\infty}u(m)\cdot u(n-m) = \\ &= \sum_{m=0}^{\infty} 1 \cdot u(n-m) = \sum_{m=0}^{\infty} u(n-m) \\ \end{align*}
The function to be summed is \$u(n-m)\$, which is equal to 1 if and only if \$n-m>0 \Leftrightarrow m < n\$.
Since the sum is carried out only for \$m>=0\$, if \$n>=0\$ the result is actually \$n+1\$, but if \$n<0\$ the result is 0, therefore they should have written:
\[ \sum_{m=-\infty}^{\infty}x(m)\cdot h(n-m) = (n+1)u(n) \]
rightaway.
The following image may help:
the red dots are the function values, the green shaded area highlights the value range that will be summed. The image was drawn with \$n = 3\$. You may infer that if \$n<0\$ the green area will disappear, indicating there is nothing to sum.
u(n) is like the Heaviside function in Laplace, it ensures that y(n)=0 for n<0, which must be the case. If you just wrote y(n)=n+1, then y(n) would have negative values for negative n
