I have a question that seems to baffle electricians that I've spoken to. I'm running a 115V Fan off a TRIAC controller that utilizes a 0-10VDC control signal. When I power the DC control signal down, the fan stops running as expected. However, when I take voltage readings at the fan terminal box I get 120V readings from Line/Ground and 120V from Neutral/Ground but zero volts from Line/Neutral. Can somebody explain this to me?
  • 4
    \$\begingroup\$ I'd guess that your controller is switching the Neutral line and therefore Live is always connected. Whether or not this is a good idea is a different question ... \$\endgroup\$
    – brhans
    Commented Jun 9, 2015 at 17:21
Assuming there is a neutral to ground connection somewhere between your supply transformer and your building ...
Figure 1. Switched neutral.
It sounds as though the triac controller is in the neutral line.
That's the VM1 reading.
That's VM3. The live feed is coming through the lamp filament.
That's VM2. The lamp is off and there is no voltage drop across it.
  1. pl. check the earthing (ground)..perhaps it is floating
  2. Instead of checking voltage by voltmeter, pl. check the voltage by 240 V filament bulb..vtingole
