6
Is it ever a good idea to add a capacitor between the inputs of an op amp?
I'm building an electronic load roughly inspired by some of the Dave Jones derivative circuits out there. I've adopted the standard of being able to fully explain the role of each component in the circuit so I can learn the most from the exercise, and so it's almost as if I've designed the circuit from scratch when I'm done.
One of the popular builds is depicted here: User @kibi electronic load
(from http://mjlorton.com/forum/index.php?topic=29.msg92#msg92)
Notice that C5 (10nF) is attached across the inputs of IC2B. The poster mentioned that he was only able to achieve stability by adding that capacitor.
Something about seeing a capacitor there just seems wrong to me, but being something of a beginner with op amps, I thought maybe I was missing something and just haven't come across that before. The reading I've done on op amp stability seemed to indicate that capacitance on the inputs was a negative factor and something to be compensated for, not added.
I don't actually have a stability problem in my circuit, not yet at least, although I do have bypass capacitors (0.1uF) in there from Vcc to ground and from the non-inverting input to ground (to filter out EMI from the reference voltage pot.
Is adding a capacitor across the inputs ever a good idea or did the designer just get lucky in this case?
    \$\begingroup\$ Normally, when you want to roll off the high-frequency response, you have a capacitor from the output of the op-amp to the negative input, which reduces the loop bandwidth. \$\endgroup\$ Jun 14, 2015 at 23:33
    \$\begingroup\$ Who is Dave Jones? \$\endgroup\$
    Jun 15, 2015 at 7:38
  • \$\begingroup\$ @Andyaka Funny Aussie bloke with a really "characteristic" way of talking (people either hate or love it). Former Altium guy and USENET denizen, he's doing vblogs now, got his own forums, selling product, etc. Generally knows his stuff and has a following. \$\endgroup\$ Jun 15, 2015 at 11:21
I think he got lucky- that hairball haywired circuit probably had some inductance that caused the oscillation. High currents only require a small layout issue to cause feedback voltage to show up- at the 750kHz that he reported and several amperes it wouldn't take much.
In answer to your question, yes there is a valid reason to use such a capacitor even though it generally reduces stability. It has to do with EMI sensitivity of op-amp front ends which can produce an apparent DC offset via nonlinearity of the front end response. Since low level signal generally require high gain, stability is less of an issue than it would be with a very low gain circuit.
    \$\begingroup\$ A capacitor at the input will usually resolution a very high noise output. At high frequencies ('High' depends on the opamp and the capacitor and resistor values) the feedback is attenuated resulting in a high-gain for amplifier internal noise. \$\endgroup\$ Jun 15, 2015 at 1:32
