I have a usage case where I would like a potentiometer for controlling the charge going to a lead-acid battery via a IC. It would be susceptible to some (although not extreme) vibration, such people carrying it around and various bumps.
It would for most part be a set-and-forget thing hidden in a case that nobody will think of, unless the battery type was changed. I don't want the resistance to go shifting over time, it should ideally remain reasonably stable within a few percent.
How can I evaluate if a potentiometer is stable enough to use for this purpose?
