I need to use the best model for the MOSFET in my circuit I'm simulation on PSIM, the MOSFET is Si4108-TI-GE3.
But I am not given the parasitic capacitance values (Cgs Cds Cdg), I am only given this:
dynamic charge characteristics of the capacitor to be modeled
I think I should use Q=CU, but I don't see how to use Q=CU for Cds since I only have Total gate charge and I don't know if that is the drain-source charge. How do I calculate the necessary parasitic capacitance values?
  • \$\begingroup\$ Generally, Q=CV \$\endgroup\$
    – Eugene Sh.
    Jun 17, 2015 at 15:55
Read the data sheet: -
Ciss is gate-source capacitance. You should be able to work out the other two.
  • \$\begingroup\$ reading the datasheet doesn't help if you don't know what you're looking for! I assume that is why the OP asked the question. \$\endgroup\$
    – jrive
    Nov 14, 2023 at 20:56
  • \$\begingroup\$ @jrive so, you think on that basis (your opinion) it's OK to downvote my answer then? Did you notice that the op accepted this answer and therefore your concerns are somewhat badly displaced from the OP's. \$\endgroup\$
    Nov 14, 2023 at 21:19
  • \$\begingroup\$ yes….I find those types of answers discouraging to people who are seeking help. Apologies if misinterpreted your intent. \$\endgroup\$
    – jrive
    Nov 19, 2023 at 1:11
10
I realize that I am very late to the party but the question remains unanswered.
Cgd = Crss
Cgs = Ciss - Crss
Cds = Coss - Crss
You'll need to pick the values at the operating conditions you are working at.
This video should give some ideas https://youtu.be/iATO3mUKBPc
The capacitances vary significantly with voltage so it's not so easy. (A different MOSFET)
Here is a SPICE model for the si4108:
