I am beginner at programming uC's. I have read all the tutorials on what is I2C and how it works, but I couldnt find any help specific on how to create a connection between my sensor and ATTiny88 (ATTiny88 datasheet.
I use SHT21 sensor (SHT21 datasheet) and want to communicate with ATTiny88 (MUC sends command to getData, and then sensors sends to MUC back the data (temperature, humidity)) - can someone help me guide through?
Once you help me, I'll understand it for future, but I really need a jump start here.
Thanks!
I have done I2C Communications for the Atmega32 and I interfaced a temperature sensor. Looking at the datasheet ATtiny and atmega has the same registers for I2C Communications. So you can use the following code I made for I2C Communication
This function will write the data to the I2C bus:
void i2c_write(unsigned char data)
  TWDR = data ;
  TWCR = (1<< TWINT)|(1<<TWEN);
  while ((TWCR & (1 <<TWINT)) == 0);
This function will start the I2C Communication:
void i2c_start(void)
  TWCR = (1 << TWINT) | (1 << TWSTA) | (1 << TWEN);
  while ((TWCR & (1 << TWINT)) == 0);
This function will stop the communication:
void i2c_stop()
  TWCR = (1<< TWINT)|(1<<TWEN)|(1<<TWSTO);
This function will initiate the I2C bus:
void i2c_init(void)
  TWSR=0x00;
  TWBR=0x47;
  TWCR=0x04;
Now you can use these functions in you main
int main (void)
  i2c_init();
  i2c_start();
  i2c_write(address);
  i2c_write(address);
  i2c_stop();
  while(1);
  return 0;
NOTE: Make the last bit of your address to 0 for writing and 1 reading from the i2c bus
you should try to check examples:
http://www.atmel.com/devices/ATTINY88.aspx?tab=documents
I see plenty of example on the I2C.
You should read them, understand them than try to implement them for your own application.
Regards, Mathieu L.
  • \$\begingroup\$ The probably i dont know which one of those documents i need to select. Because, unless i'm blind, i cannot find in titles of those docs "I2C communication" nor "communicating with sensor". You have to consider i'm a beginner in this, trying to learn before applying to university.. \$\endgroup\$ Jun 17, 2015 at 22:06
  • \$\begingroup\$ Look in the brief descriptions, as well as the titles. Also, look for "TWI" (Two Wire Interface) - one description says "TWI (I2C compatible)". \$\endgroup\$ Jun 17, 2015 at 22:38
