I'd like a process to listen to changes in a signal, but not before 20 ns. How can I achieve that?
It doesn't seem possible to use wait statements in such a process, which makes sense since is has a sensitivity list.
What I'm really trying to achieve is a test bench that changes one signal indefinitely and another for like 5 ns after signal ready = '1'. But I don't know precisely when that will happen. I only know that before 20 ns the system is still resetting and hence I should not listen to changes in ready before 20 ns because then I'd get errors.
Alternatives to the approach in the question are welcome.
  • \$\begingroup\$ if ready = '1' and reset = '1' is probably a good alternative to dictate what should be done in the first 20 ns \$\endgroup\$ Jun 18, 2015 at 9:08
  • \$\begingroup\$ Run a fast clock. Start incrementing a counter on ready. Ignore changes to the other signal until the counter is high enough. \$\endgroup\$
    – David
    Jun 18, 2015 at 9:09
    \$\begingroup\$ Perhaps you could do a little research on processes and wait statements. A sensitivity list is the equivalent of placing a `wait on sensitivity_list; as the last statement in the process. If a process sensitivity list and wait statements are mutually exclusive and the process with a sensitivity has an implied wait statement, why not make that explicit? \$\endgroup\$
    – user8352
    Jun 18, 2015 at 9:45
  • \$\begingroup\$ I interpreted the question as referring to wait for 20ns which obviously won't work in real hardware. \$\endgroup\$
    – David
    Jun 18, 2015 at 11:40
For much testbench code, we do not use looping processes and process sensitivity lists to search for things. Instead, we use wait to find events.
TestProc : process
begin
  Out1 <= '1' ; -- Steady 1 after this point.
  -- Find Reset as it deactivates
  -- a better alternative than waiting for an ad-hoc amount of time
  if Reset /= ACTIVE then
    wait until Reset = ACTIVE ;
  end if;
  wait until Reset /= ACTIVE ;
  -- find ready at a level 1
  if ready /= '1' then
    wait until ready = '1' ;
  end if ;
  Out2 <= '1' after 5 ns ;
  -- find a rising edge of Clock
  -- Assumes that clock always transitions from 0 to 1
  wait until Clk = '1' ;
  Out2 <= '0' after 5 ns ;
  -- Also find a rising edge of Clock
  -- rising_edge is extra work for the simulator and probably not necessary here
  wait until rising_edge(Clk) ;
  std.env.stop ; -- stop the testbench
end process TestProc ;
If you are looking for a behavioral model that drives Out1 to a static value, but inverts Out2 5 ns after each time Ready rises to a 1, then you can do the following:
signal Out2 : std_logic := '0' ;
FollowReady : process
begin
  -- initialization
  Out1 <= '1' ;
  wait for 20 ns ;
  -- looping process like behavior
  loop
    -- Ready is a design signal.  Only detect a 0 to 1 change
    wait until rising_edge(Ready) ;
    Out2 <= not Out2 after 5 ns ;
  end loop ;
end process ;
To avoid a process with a sensitivity list and a wait statement, you can simply something like that :
Method 1:
Process 1 (No sensitivity list) containing the following:
Out1 <= '1';
wait for 20 ns;
Out1 <= '0';
wait;
Process 2 (The one with a sensitivity list) containing this:
if Ready = '1' then
  -- track signal changes
else
  -- stay idle
end if;
Method 2:
If your VHDL code is to be synthesized, I would try something different, also using two different processes.
It assumes that the changes on the signal you are tracking are not faster than your clock.
Process 1 detects changes on the signal:
edge_detector : process (Clk, Reset_n)
    begin
    if Reset_n = '0' then
        edge_detected <='0';
        old_s_signal <='0';
    elsif rising_edge(Clk) then
            if old_s_signal='1' and s_signal='0' then
                edge_detected<='1';
            else
                edge_detected<='0';
            end if;
            old_s_signal<=s_signal;
    end if;
end process;
Process 2 waits for 20 ns and then takes actions when a change is seen on the signal:
tracker : process (Clk, Reset_n)
variable cpt_wait : integer;
begin
    cpt_wait := '0';
    -- initialize all other variables and signals assigned in this process here
        if cpt_wait = NB_OF_TCLK_TO_MAKE_20_NS then
            if edge_detected = '1' then
                -- track changes
            end if;
        else
           cpt_wait := cpt_wait + 1;
        end if;
 end if;
end process;
