Here Altium PCB on the picture. I rotate component on 45 degree and place it on the PCB.
- What is gray area under the component?
- Should it be rotated also?
- Can it be a problem if it s not rotated?
- How can I rotate it if necessary?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityHere Altium PCB on the picture. I rotate component on 45 degree and place it on the PCB.
The gray rectangle under the selected component is just a visual indicator that you currently have this component selected. It's just a simple, automatic "box" Altium places there. You can not select, edit or modify this gray indicator box in any way. (At least i don't know any, and i've been working with this tool since 1998. Maybe you could set some parameters in the vast forest of Altiums configurations to hide it or change the appearance, but it would not make much sense to do that imho.)
