I am building a small command interpreter to be run on a microcontroller. To queue each command and its accompanying arguments, I am using a queue implemented as a singly linked list. All of the queue operations work, however there seems to be a memory leak. When I look at the available ram at run time the numbers don't seem to add up. The program posted below under "main.c" will just queue up 100 elements of "012345", then dequeue them and report the available sram after each operation by measuring the difference between the top of the stack and the top of the heap. The behavior is a bit unusual... Please take a look at the code below, I'm sure I am just doing something remarkably stupid.
Here are a few details about the system: Microcontroller: ATmega2560-16AU Language: C, Development Environment: Atmel Studio 6 with avr gcc
main.c
#include <avr/io.h>
#include "setup.h"
#include "stdlib.h"
#include "string.h"
#include "StringQueue.h"
#define TEST_STR "012345"
strqueue_t qCommands, qArgs;
struct gFlags
uint8_t returnCharacterRecieved;
}gFlags;
enum states
idle,
invoke,
exec,
error
//testing
uint16_t free_ram();
uint16_t free_ram()
extern uint16_t __heap_start, *__brkval;
uint16_t v;
return (uint16_t) &v - (__brkval == 0 ? (uint16_t) &__heap_start : (uint16_t) __brkval);
int main(void)
_delay_ms(500);
uart_init(&UART0);
stdout = &outputStream;
printf("-------------------------------------------------\n");
printf("Command Interpreter Test\n");
printf("Hardware:\n\tATmega2560p\n");
printf("Initialization complete...\n");
printf("free sram:\t%d\n", free_ram());
printf("creating qCommands queue...");
queueCreate(&qCommands, 0);
printf("element size:\t%d\n", strlen(TEST_STR));
printf("starting memory allocation test...\n");
for(volatile uint8_t runs = 0; runs < 1; runs++)
printf("enqueueing elements...");
for(volatile uint8_t i = 0; i < 100; i++)
enqueue(&qCommands, TEST_STR);
puts(queueFront(&qCommands));
printf("num elements:\t%d\n", queueSize(&qCommands));
_delay_ms(50);
_delay_ms(1000);
printf("dequeueing elements...\n");
while(!queueIsEmpty(&qCommands))
dequeue(&qCommands);
_delay_ms(50);
sei();
while(1)
if(gFlags.returnCharacterRecieved)
while(uart_data_available(&UART0))
enqueue(&qArgs, (char *)uart_read_byte(&UART0));
printf("enq value:\t%s\n", queueFront(&qArgs));
gFlags.returnCharacterRecieved = 0;
ISR(USART0_RX_vect)
if(bit_is_clear(UCSR0A, UPE0))
UART0.incomingData = UDR0;
UART0.recieveFlag = 1;
uint8_t i = (uint16_t)(UART0.rxHead + 1) % BUFF_SIZE;
if(i != UART0.rxTail)
UART0.rxBuffer[UART0.rxHead] = UART0.incomingData;
UART0.rxHead = i;
else
//UDR0;
// check for return character, if received, flag main process
if(UART0.incomingData == '\n')
gFlags.returnCharacterRecieved = 1;
StringQueue.h
#ifndef StringQueue_h
#define StringQueue_h
#include "stdlib.h"
#include "stdint.h"
#include "string.h"
#include "stdio.h"
#define MAX_ELEMENTS 32
//!<@struct node_t
typedef struct
char * data; //!< string for node data
struct node_t * nodePtr; //!< link to next node, may be NULL to indicate rear
}node_t;
//!<@strqueue_t
typedef struct
node_t *front; //!< front node_t
node_t *rear; //!< rear node_t
node_t *tempA; //!< temp node_t for certain operations
node_t *tempB; //!<
uint8_t nodeCount; //!< current number of node_ts
uint8_t maxElements; //!< maximum number of node_ts
}strqueue_t;
extern char * queueFront(strqueue_t * queue);
extern uint8_t enqueue(strqueue_t * queue, const char * str);
extern char * dequeue(strqueue_t * queue);
extern uint8_t queueIsEmpty(const strqueue_t * queue);
extern void queueDisplay(strqueue_t * queue);
extern void queueCreate(strqueue_t * queue, uint8_t elements);
extern uint8_t queueSize(const strqueue_t * queue);
extern uint8_t queueIsFull(const strqueue_t * queue);
#endif
StringQueue.c
* @brief [brief description]
* @details [long description]
* @param strqueue_t [description]
* @return [description]
if ((queue->front != NULL) && (queue->rear != NULL))
return (queue->front->data);
else
return 0;
* @param str [description]
// if first element and last element in queue. i.e. no allocations yet
if(queue->rear == NULL)
queue->rear = (node_t *)malloc(strlen(str) + sizeof(node_t) );
queue->rear->nodePtr = NULL; // null link
queue->rear->data = str;
queue->front = queue->rear;
// if any elements exist so fart
else
queue->tempA = (node_t *)malloc(strlen(str) + sizeof(node_t));
queue->rear->nodePtr = (queue->tempA); // link to next rear node
queue->tempA->data = str;
queue->tempA->nodePtr = NULL; //ensure rear maintains null link
queue->rear = queue->tempA;
return queue->nodeCount++;
queue->tempB = queue->front;
char *tempStr = NULL;
if(queue->tempB == NULL)
// list is empty
return 0;
else
if (queue->tempB->nodePtr != NULL)
queue->tempB = queue->tempB->nodePtr;
//free(queue->front->data); // free memory occupied by the head data
free(queue->front); // free memory occupied by head node
queue->front = queue->tempB; // move head back
else
free(queue->front); // free memory occupied by the head node
queue->front = NULL; // reset list to empty
queue->rear = NULL; // reset list to empty
queue->nodeCount--;
return (tempStr == NULL ? 0 : tempStr);
* @param queue [description]
uint8_t queueIsEmpty(const strqueue_t *queue)
if(queue->front == NULL && queue->rear == NULL && queue->nodeCount == 0)
return 1;
else
return 0;
void queueDisplay(strqueue_t *queue)
// check for empty list
if((queue->tempB == NULL) && (queue->rear == NULL))
//printf("Queue empty...\n");
putchar('-');
return;
// while list is not empty, print contents
while(queue->tempB != queue->rear)
printf("%s\n", queue->tempB->data);
if(queue->tempB == queue->rear)
* @param elements [description]
queue->rear = NULL;
queue->tempA = NULL;
queue->tempB = NULL;
queue->nodeCount = 0;
if(elements == 0)
queue->maxElements = MAX_ELEMENTS;
else
queue->maxElements = elements;
return queue->nodeCount;
uint8_t queueIsFull(const strqueue_t *queue)
if(queue->front != NULL && queue->nodeCount >= MAX_ELEMENTS)
return 1;
else
return 0;
OUTPUT from putty
Hardware:
ATmega2560p
free sram: 7705
creating qCommands queue...free sram: 7699
element size: 6
enqueueing elements...012345
num elements: 1
free sram: 7689
012345
num elements: 2
free sram: 7677
012345
num elements: 3
free sram: 7665
012345
num elements: 4
free sram: 7653
012345
num elements: 5
free sram: 7641
012345
num elements: 6
free sram: 7629
012345
num elements: 7
free sram: 7617
012345
num elements: 8
free sram: 7605
012345
num elements: 9
free sram: 7593
012345
num elements: 10
free sram: 7581
012345
num elements: 11
free sram: 7569
012345
num elements: 12
free sram: 7557
012345
num elements: 13
free sram: 7545
012345
num elements: 14
free sram: 7533
012345
num elements: 15
free sram: 7521
012345
num elements: 16
free sram: 7509
012345
num elements: 17
free sram: 7497
012345
num elements: 18
free sram: 7485
012345
num elements: 19
free sram: 7473
012345
num elements: 20
free sram: 7461
012345
num elements: 21
free sram: 7449
012345
num elements: 22
free sram: 7437
012345
num elements: 23
free sram: 7425
012345
num elements: 24
free sram: 7413
012345
num elements: 25
free sram: 7401
012345
num elements: 26
free sram: 7389
012345
num elements: 27
free sram: 7377
012345
num elements: 28
free sram: 7365
012345
num elements: 29
free sram: 7353
012345
num elements: 30
free sram: 7341
012345
num elements: 31
free sram: 7329
012345
num elements: 32
free sram: 7317
012345
num elements: 33
free sram: 7305
012345
num elements: 34
free sram: 7293
012345
num elements: 35
free sram: 7281
012345
num elements: 36
free sram: 7269
012345
num elements: 37
free sram: 7257
012345
num elements: 38
free sram: 7245
012345
num elements: 39
free sram: 7233
012345
num elements: 40
free sram: 7221
012345
num elements: 41
free sram: 7209
012345
num elements: 42
free sram: 7197
012345
num elements: 43
free sram: 7185
012345
num elements: 44
free sram: 7173
012345
num elements: 45
free sram: 7161
012345
num elements: 46
free sram: 7149
012345
num elements: 47
free sram: 7137
012345
num elements: 48
free sram: 7125
012345
num elements: 49
free sram: 7113
012345
num elements: 50
free sram: 7101
012345
num elements: 51
free sram: 7089
012345
num elements: 52
free sram: 7077
012345
num elements: 53
free sram: 7065
012345
num elements: 54
free sram: 7053
012345
num elements: 55
free sram: 7041
012345
num elements: 56
free sram: 7029
012345
num elements: 57
free sram: 7017
012345
num elements: 58
free sram: 7005
012345
num elements: 59
free sram: 6993
012345
num elements: 60
free sram: 6981
012345
num elements: 61
free sram: 6969
012345
num elements: 62
free sram: 6957
012345
num elements: 63
free sram: 6945
012345
num elements: 64
free sram: 6933
012345
num elements: 65
free sram: 6921
012345
num elements: 66
free sram: 6909
012345
num elements: 67
free sram: 6897
012345
num elements: 68
free sram: 6885
012345
num elements: 69
free sram: 6873
012345
num elements: 70
free sram: 6861
012345
num elements: 71
free sram: 6849
012345
num elements: 72
free sram: 6837
012345
num elements: 73
free sram: 6825
012345
num elements: 74
free sram: 6813
012345
num elements: 75
free sram: 6801
012345
num elements: 76
free sram: 6789
012345
num elements: 77
free sram: 6777
012345
num elements: 78
free sram: 6765
012345
num elements: 79
free sram: 6753
012345
num elements: 80
free sram: 6741
012345
num elements: 81
free sram: 6729
012345
num elements: 82
free sram: 6717
012345
num elements: 83
free sram: 6705
012345
num elements: 84
free sram: 6693
012345
num elements: 85
free sram: 6681
012345
num elements: 86
free sram: 6669
012345
num elements: 87
free sram: 6657
012345
num elements: 88
free sram: 6645
012345
num elements: 89
free sram: 6633
012345
num elements: 90
free sram: 6621
012345
num elements: 91
free sram: 6609
012345
num elements: 92
free sram: 6597
012345
num elements: 93
free sram: 6585
012345
num elements: 94
free sram: 6573
012345
num elements: 95
free sram: 6561
012345
num elements: 96
free sram: 6549
012345
num elements: 97
free sram: 6537
012345
num elements: 98
free sram: 6525
012345
num elements: 99
free sram: 6513
012345
num elements: 100
free sram: 6501
012345
num elements: 99
free sram: 6501
012345
num elements: 98
free sram: 6501
012345
num elements: 97
free sram: 6501
012345
num elements: 96
free sram: 6501
012345
num elements: 95
free sram: 6501
012345
num elements: 94
free sram: 6501
012345
num elements: 93
free sram: 6501
012345
num elements: 92
free sram: 6501
012345
num elements: 91
free sram: 6501
012345
num elements: 90
free sram: 6501
012345
num elements: 89
free sram: 6501
012345
num elements: 88
free sram: 6501
012345
num elements: 87
free sram: 6501
012345
num elements: 86
free sram: 6501
012345
num elements: 85
free sram: 6501
012345
num elements: 84
free sram: 6501
012345
num elements: 83
free sram: 6501
012345
num elements: 82
free sram: 6501
012345
num elements: 81
free sram: 6501
012345
num elements: 80
free sram: 6501
012345
num elements: 79
free sram: 6501
012345
num elements: 78
free sram: 6501
012345
num elements: 77
free sram: 6501
012345
num elements: 76
free sram: 6501
012345
num elements: 75
free sram: 6501
012345
num elements: 74
free sram: 6501
012345
num elements: 73
free sram: 6501
012345
num elements: 72
free sram: 6501
012345
num elements: 71
free sram: 6501
012345
num elements: 70
free sram: 6501
012345
num elements: 69
free sram: 6501
012345
num elements: 68
free sram: 6501
012345
num elements: 67
free sram: 6501
012345
num elements: 66
free sram: 6501
012345
num elements: 65
free sram: 6501
012345
num elements: 64
free sram: 6501
012345
num elements: 63
free sram: 6501
012345
num elements: 62
free sram: 6501
012345
num elements: 61
free sram: 6501
012345
num elements: 60
free sram: 6501
012345
num elements: 59
free sram: 6501
012345
num elements: 58
free sram: 6501
012345
num elements: 57
free sram: 6501
012345
num elements: 56
free sram: 6501
012345
num elements: 55
free sram: 6501
012345
num elements: 54
free sram: 6501
012345
num elements: 53
free sram: 6501
012345
num elements: 52
free sram: 6501
012345
num elements: 51
free sram: 6501
012345
num elements: 50
free sram: 6501
012345
num elements: 49
free sram: 6501
012345
num elements: 48
free sram: 6501
012345
num elements: 47
free sram: 6501
012345
num elements: 46
free sram: 6501
012345
num elements: 45
free sram: 6501
012345
num elements: 44
free sram: 6501
012345
num elements: 43
free sram: 6501
012345
num elements: 42
free sram: 6501
012345
num elements: 41
free sram: 6501
012345
num elements: 40
free sram: 6501
012345
num elements: 39
free sram: 6501
012345
num elements: 38
free sram: 6501
012345
num elements: 37
free sram: 6501
012345
num elements: 36
free sram: 6501
012345
num elements: 35
free sram: 6501
012345
num elements: 34
free sram: 6501
012345
num elements: 33
free sram: 6501
012345
num elements: 32
free sram: 6501
012345
num elements: 31
free sram: 6501
012345
num elements: 30
free sram: 6501
012345
num elements: 29
free sram: 6501
012345
num elements: 28
free sram: 6501
012345
num elements: 27
free sram: 6501
012345
num elements: 26
free sram: 6501
012345
num elements: 25
free sram: 6501
012345
num elements: 24
free sram: 6501
012345
num elements: 23
free sram: 6501
012345
num elements: 22
free sram: 6501
012345
num elements: 21
free sram: 6501
012345
num elements: 20
free sram: 6501
012345
num elements: 19
free sram: 6501
012345
num elements: 18
free sram: 6501
012345
num elements: 17
free sram: 6501
012345
num elements: 16
free sram: 6501
012345
num elements: 15
free sram: 6501
012345
num elements: 14
free sram: 6501
012345
num elements: 13
free sram: 6501
012345
num elements: 12
free sram: 6501
012345
num elements: 11
free sram: 6501
012345
num elements: 10
free sram: 6501
012345
num elements: 9
free sram: 6501
012345
num elements: 8
free sram: 6501
012345
num elements: 7
free sram: 6501
012345
num elements: 6
free sram: 6501
012345
num elements: 5
free sram: 6501
012345
num elements: 4
free sram: 6501
012345
num elements: 3
free sram: 6501
012345
num elements: 2
free sram: 6501
012345
num elements: 1
free sram: 6501
012345
num elements: 0
free sram: 7701
