Here's the circuit:
$$I=2.25,0° mA$$ What's the $$n=N1/N2$$ of the transformer so that on R3 most power is dissipated. Power? U1?
What I don't know is what to do with the transformer. When it's in parallel I know. I just need help with that, else I think I would manage.
  • \$\begingroup\$ Like Russel McMahon said, it's an autotransformer, but your drawing obscures the fact. A more conventional way to draw it would be as one coil with a tap in the middle, and a double bar that signifies the iron core. commons.wikimedia.org/wiki/File:Autotransformer.png \$\endgroup\$ Commented Jun 19, 2015 at 16:59
It's called an "auto transformer.
It obeys the usual rules for an ideal transformer
Call the voltage at the right hand end of R2 "Vin"
Short:
  • Vin is divided between N1 & N2 in the ratio of their turns
    (as in any transformer) so -
  • \$ Vout = \dfrac{N2}{N1+N2} \$
Longer:
$$ Vn2 = Vn1 \times N2/N1 \tag1 $$
So $$ Vn1 = Vn2 \times N1/N2 \tag2 $$
By inspection
$$ Vin = Vn1 + Vn2 \tag3 $$
So
$$ Vn1 = Vin - Vn2 ... \tag4 $$
From 2 & 4
$$ Vn2 \times N1/N2 = Vin - Vn2 $$ $$ Vn2 \times (N1/N2 +1 ) = Vin $$ $$ Vn2 = \dfrac{Vin}{N1/N2 + 1} $$ $$ Vn2 = \dfrac{Vin}{(N1 + N2) / N2} $$
$$ Vn2 = \dfrac{Vin \times N2}{N1 + N2} $$
i.e., MUCH more simply,
Vin is divided across N1 and N2 in the ratio of their turns.
Example
If N1:N2 = 1:9 Vout is 90% of Vin.
If N1:N2 = 9:1 Vout is 10% of Vin.
Wikipedia - autotransformer
Autotransformer basics
Autotransformers
Many examples
