I am quite new to electronics and hoping to build a voltage regulator using the schematic below. I will be using a 7806 regulator and a 7.4 Lipo battery (yes, the schematic is probably a little overkill for 6V regulation but never mind that). The transistor required is a TIP2955 which is a PNP transistor.
A website I came across says this about PNP transistors:
Only when there is no current at the base will it turn on. And to ensure that no current enters the base, the base must be grounded (connected to ground). If any current goes into the base of a PNP transistor at all, the transistor will not conduct across from emitter to collector.
The schematic shows the PNP's base connected to positive, not ground. Will this schematic work and how? I'm rather confused as the preceding description seems to imply that it won't.
(source: zen.co.uk)
