I've been playing around with some ideas about building my own inverting power supply, to power AC devices from a car battery. I've heard of designs that just feed a square wave into a transformer to get the mains voltage output, but I've also heard vague claims about how you shouldn't do that. In what ways can powering devices engineered to run off a sine wave with a square wave impact their functioning?
    \$\begingroup\$ Just think about it this way: The rotor of a fridge motor just doesn't like to get a gigantic kick 100 times per second, first in one way then the other way. A motor like that rather likes to be taken by the hand and gently pulled around its axis, just like a sine wave does. \$\endgroup\$ – jippie Jun 20 '15 at 7:01
AC-mains appliances are engineered to present a certain impedance (load) for the specific 50/60Hz mains frequency. Feeding them a square wave of the same (fundamental) frequency is - mathematically provably - the same thing as feeding them not just a sine wave of 50/60Hz, but super-imposed on that also a 150/180Hz at 1/3 the amplitude, and a 250/350Hz sine wave at 1/5th the amplitude, and a 350/420Hz sine wave at 1/7th the amplitude (i.e. all the odd harmonics at decreasing amplitudes) and so on, in theory up to infinite frequency, but in practise with domestic wiring the losses & impedances in mains distribution networks & appliances, they peter out at kHz or maybe 10s of kHz (for a 50/60Hz fundamental). These higher frequencies are the result of the high rise-time & fall-time of a square wave.
For some appliances this doesn't matter so much - like resistive loads (e.g. heater elements). For inductive loads (e.g. motors) or some capacitive loads, that typically means a significant proportion of the energy you're hoping to deliver into the appliance won't actually be used for 'work', but will instead be dissipated as heat, because the inductive/capacitive load is tuned for 50/60Hz, not the higher frequencies. So, depending on the specifics of the appliance, powering them from a "square-wave inverter" might work ok, might not, or might even damage it permanently, it all depends on the specifics of the appliance. Even low power switch-mode power supplies that in one respect would be more impervious to this kind of treatment, actually aren't, and will in fact deliver poorer (noisier) DC to their electronic circuits, hence gadgets "play up".
The short story is, the DC-to-AC inverter industry for the last few decades has gone through a maturation process of inverter designs to overcome this severe shortcoming of square-wave inverters, first with 'modified sine wave' (a misnomer, actually a 'modified square wave' where there's an off-period on either side of the 'zero crossing'; and then on to "pure sine wave" inverters, which also aren't really sine waves. Some filtering with inductors & capacitors can also help to slow down the fast transitions of square-wave, but because of the low frequencies involved, they're large components & therefore expensive. Modern 'sine wave' inverters create a bi-polar wave via a modulated PWM at a much higher frequency (say, a few kHz or even 10s of kHz), which can be filtered out to achieve something more resembling a sine-wave (at least under load).
  • \$\begingroup\$ I knew about the crazy harmonics in square waves, but I didn't even think about how those frequencies would interact with components engineered for only the mains line frequency. \$\endgroup\$ – Robbie Mckennie Jun 20 '15 at 6:03
I have two inverters (actually two UPSs) with modified square/sine wave output on one unit, and a pure sine wave on the other one. Waveforms are verified using a scope meter, just to be sure if manufacturer's claim is true, considering that the devices had been in use for two or more years.
With all kinds of loads - of course within the capacity of the inverter/UPS which is only 1000 watts (1kW), the pure sine-wave is working fine with no noticeable effect. Effect is also the same with the modified sine/square wave unit, except for the AC electric fan. When I connected the ordinary electric fan, there was a hum and slight vibration, and after a few minutes it stopped. No burning smell, no abnormal heat, and no visible burns on the windings when I opened it, and no open wirings when tested. I cannot make it run again even if it is connected to the regular outlet even before I disassembled it for internal inspection and testing. I had to replace the fan motor before I was able to use the electric fan again.
I concluded that inverters with modified sine/square wave output cannot be used on motor loads.
