I need a P-channel depletion-mode MOSFET for a circuit I'm building. However, there is no model available in LTspice that I have found, nor is there any available that I have found to buy online.
How can I simulate this kind of MOSFET in LTspice, and where can I get one?
    \$\begingroup\$ There was a very similar question asked before. \$\endgroup\$ – The Photon Jun 20 '15 at 5:42
    \$\begingroup\$ Also this one. \$\endgroup\$ – The Photon Jun 20 '15 at 5:48
  • \$\begingroup\$ My fault. Didn't search thoroughly. \$\endgroup\$ – Allenph Jun 20 '15 at 5:51
The answer is in the LTSpice docs:
VTO is positive (negative) for enhancement mode and negative (positive) for depletion mode N-channel (P-channel) devices.
You can make a depleteion mode PMOS device by setting VTO positive in the .MODEL card.
