i know this might be a very simple question . i have to simulate some delays for various adders in ISE Suite . ( i'm a little familiar with vhdl concepts but ISE Environment , not at all ! )
this is the vhdl Code for Carry select adder :
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use work.all ;
library UNISIM;
use UNISIM.VComponents.all;
entity csa is
  generic (
    WIDTH : natural := 32 -- adder will add WIDTH bits, should be a power of 2
-- some port mappings ..
end csa;
architecture csa_arch of csa is
  component csa is
    generic (
      WIDTH : natural
    port (
      op_1  : in std_logic_vector(WIDTH-1 downto 0);
      op_2  : in std_logic_vector(WIDTH-1 downto 0);
      c_in  : in std_logic;
      sum   : out std_logic_vector(WIDTH-1 downto 0);
      c_out : out std_logic
  end component;
  signal sum_loc_0   : std_logic_vector(WIDTH-1 downto 0);
  signal sum_loc_1   : std_logic_vector(WIDTH-1 downto 0);
  signal c_out_loc_0 : std_logic_vector(1 downto 0);
  signal c_out_loc_1 : std_logic_vector(1 downto 0);
begin
  base_case : if (WIDTH = 1) generate
   full_adder_0 : full_adder -- GENERATES ERROR --
      port map (
        op_1  => op_1(0),
        op_2  => op_2(0),
        c_in  => '0',
        sum   => sum_loc_0(0),
        c_out => c_out_loc_0(1)
  end generate;
and the line creating a component of the full adder entity rises tthe error :
Line 44: full_adder is not a component
the full adder is defined in a seprate file : ( in teh same project as another vhdl module )
library IEEE;
library work ;
library UNISIM;
entity full_adder is
port (
    op_1  : in std_logic;
    op_2  : in std_logic;
    sum   : out std_logic;
end full_adder;
architecture full_adder_arch of full_adder is
begin
    sum   <= op_1 xor op_2 xor c_in;
    c_out <= (op_1 and c_in) or (op_2 and c_in) or (op_1 and op_2);
end full_adder_arch;
There are three ways to instantiate components in VHDL, through the use of direct entity instantiation, instantiating a declared component and instantiating a configuration of an entity.
The first two of these are shown below:
library ieee;
use ieee.std_logic_1164.all;
-- use IEEE.NUMERIC_STD.ALL;
-- library work ;
-- library UNISIM;
-- use UNISIM.VComponents.all;
    port (
        op_1:   in  std_logic;
        op_2:   in  std_logic;
        c_in:   in  std_logic;
        sum:    out std_logic;
        c_out:  out std_logic
end full_adder;
begin
library ieee;
-- use work.all ;
-- library UNISIM;
entity csa is
    generic (
        WIDTH:  natural := 32 -- adder will add WIDTH bits, should be a power of 2
    port (
        op_1:   in  std_logic_vector(WIDTH-1 downto 0);
        op_2:   in  std_logic_vector(WIDTH-1 downto 0);
        c_in:   in  std_logic;
        sum:    out std_logic_vector(WIDTH-1 downto 0);
end entity csa;
architecture component_instantiation of csa is
    -- component csa is
    --     generic (
    --         WIDTH:  natural
    --     port (
    --         op_1:   in  std_logic_vector(WIDTH-1 downto 0);
    --         op_2:   in  std_logic_vector(WIDTH-1 downto 0);
    --         c_in:   in  std_logic;
    --         sum:    out std_logic_vector(WIDTH-1 downto 0);
    --         c_out:  out std_logic
    -- end component;
    component full_adder is
        port (
        op_1:   in  std_logic;
        op_2:   in  std_logic;
        c_in:   in  std_logic;
        sum:    out std_logic;
    end component;
    signal sum_loc_0:    std_logic_vector(WIDTH-1 downto 0);
    signal sum_loc_1:    std_logic_vector(WIDTH-1 downto 0);
    signal c_out_loc_0:  std_logic_vector(1 downto 0);
    signal c_out_loc_1:  std_logic_vector(1 downto 0);
begin
base_case:
full_adder_0:
            port map (
                op_1  => op_1(0),
                op_2  => op_2(0),
                c_in  => '0',
    end generate;
end architecture;
architecture direct_entity_instantiation of csa is
    -- component csa is
    --     generic (
    --         WIDTH:  natural
    --     port (
    -- end component;
begin
base_case:
full_adder_0:
        entity work.full_adder -- GENERATES ERROR --
            port map (
                op_1  => op_1(0),
                op_2  => op_2(0),
                c_in  => '0',
    end generate;
end architecture;
The entity and architecture for full_adder is included for the second csa architecture (direct_entity_instantiation).
Note that there is an implied library declaration for the library simple name work in VHDL. A use clause specifying use work.all; would make all the declarations for primary units in the current working library available. The architecture direct_entity_instantiation could have taken advantage of that and not used a selected name to specify full_adder in the generate statement.
I analyzed both architectures, and verified they work with the generic WIDTH set to 1. Elaborating and running tells us there's no connectivity issues for width 1.
A component instantiation with a component declaration does not require the full_adder to analyze, but does require it be analyzed before csa for elaboration.
Likewise the direct entity instantiation requires full_adder be found in the working library to analyze csa successfully.
See IEEE Std 1076-2008 11.7 Component instantiation statements.
1) You are declaring component csa inside the architecture of csa, which is a) illegal, b) unnecessary.
2) You should declare the full_adder component inside the architecture header in order to instantiate it.
    \$\begingroup\$ It's possible to describe recursive hardware. Of cause you should limit the recursion depths by a decreasing generic value and a generate statement :). \$\endgroup\$
    – Paebbels
    Jun 22, 2015 at 17:32
  • \$\begingroup\$ @Paebbels Can you describe some simple example of such a code? For me it's like a box, containing a box of the same size (unless you use the recursion to describe a simple iteration...) \$\endgroup\$
    – Eugene Sh.
    Jun 22, 2015 at 17:35
  • \$\begingroup\$ For example if you unroll an algorithmn (for pipelined calculation) that uses less input bits in every calculation step. Then DATA_BITS decreases until it is 1. You could also use a generate loop, but this resulted in my case in more warnings of unused signals :). \$\endgroup\$
    – Paebbels
    Jun 22, 2015 at 18:57
  • \$\begingroup\$ @Paebbels Is it actually a component consisting of the same component with different parameters? \$\endgroup\$
    – Eugene Sh.
    Jun 22, 2015 at 19:08
  • \$\begingroup\$ Yes, only the values of the generic parameters are changing. \$\endgroup\$
    – Paebbels
    Jun 22, 2015 at 20:06
