I have written a code to check the difference in assigning output before "end process" and after "end process" in VHDL. And the results of the simulation I have posted with it. enter image description here enter image description here What I found is assigning output 1:After "end process" there is no delay, output port is reflected with change in variable. 2:Before "end process" there is a pulse delay. but I'm not able to conclude it.
entity signal_delay is
port (clock_50M: in Std_logic;
        r: in std_logic;
        r_delay1, r_delay2: out std_logic);
end signal_delay;
architecture ada of signal_delay is
 signal r_1,r_2: std_logic;
 begin
     process(clock_50M)
     begin
        if ( clock_50M='1') then
            r_1<= r;
            r_2<=r_1;
        end if ;
     end process;
    r_delay1<=r_1;
    r_delay2<= r_2;
 end ada;
----case:2-------------------------------------------------------------
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
        r: in std_logic;
end signal_delay;
begin
    process(clock_50M)
    begin
        if (clock_50M 'event and clock_50M='1') then
            r_1<= r;
            r_2<=r_1;
        end if ;
        r_delay1<=r_1;
        r_delay2<= r_2;
    end process;
end ada;
    \$\begingroup\$ It would be nice if the code was formatted a little! \$\endgroup\$ – copper.hat Jun 23 '15 at 6:20
In a sequential process the signal is assigned with the next event. If it is not in a clocked process the signal is assigned immediately.
But another thing is you have this block in your VHDL description:
process(clock_50M)
begin
        r_1<= r;
        r_2<=r_1;
    end if ;
    r_delay1<=r_1;
    r_delay2<= r_2;
end process;
This is not synthesised in a way you want.
  1. You should put the r_delay1 <= r_1; and r_delay2 <= r_2; inside the if to determine on which clock edge it should happen. There are no Flip Flops reacting to both.
  2. Do not use clock_50M 'event and clock_50M='1' use rising_edge(clock_50M) it is more readable
