-1
I have a Time-Clock (Where employee's check-in and check-out to track working time).
Currently set up like this: 12V Adapter >> Time Clock
So whenever that 12V adapter loses power, the time clock loses power. This makes the Time Clock lose the current time. So I need that Time Clock to have power 24/7, even if there is a short power outage.
I purchased a 12V/7Ah sealed Lead Acid battery.
Would it be safe to set it up like this: 12V Adapter >> 12V Battery >> Time Clock
The adapter would be directly connected to the BATTERY and the TIME CLOCK. That way, when the 12V adapter loses power, the time-clock will still be powered by the battery.
Would this damage the battery? Is this safe?
    \$\begingroup\$ Replace the adapter with a proper charger. \$\endgroup\$ – Ignacio Vazquez-Abrams Jun 23 '15 at 20:56
  • \$\begingroup\$ possible duplicate of charging battery while under load... \$\endgroup\$ – George Jun 23 '15 at 21:08
  • 4
    \$\begingroup\$ Why not just get an uninterruptible power supply (UPS)? I'm pretty sure there are 3-6 outlet ones that cost less than $50. \$\endgroup\$ – DigitalNinja Jun 23 '15 at 21:09
  • \$\begingroup\$ So using the normal adapter won't work? I also have a 12V charger, but that is only 120 mAh. Will that work? \$\endgroup\$ – user3610776 Jun 23 '15 at 21:11
It depends a little on the type of Lead Acid battery you got what would be the best to do.
First thing to realise is that a 12V Lead Acid battery is not really 12V, it's between 11V and 13V, or up to 14V if gel-based when it's being used and not charged.
A normal charger will peak off at about 2.45V per cell and then let it to float-charge at about 2.3V-ish. So with a 12V battery with 6 cells that makes 14.7V peak charging voltage. That may be too much for your clock to handle, probably it'll be okay, but check that before you decide for a normal battery charger.
If you have a deep-cycle battery they like one treatment, while starter batteries (normal Motorcycle/Car batteries for example) like another.
In general, with easy to get batteries it's best to assume they are pulse or starter batteries, in which case they should be perfectly happy to exist for a decade or more being powered at a constant voltage a little below their maximum charge voltage.
So if you keep it at 13.5V (<= 2.25V per cell) it should on average be fine. You might only get 5.5Ah of capacity kept at that level, but the chance of Sulphating the battery is lower, which then statistically improves its life expectancy.
If you then have a safely current limited adapter at 13.5V that limits to about 1A, or at most 300mA above average use of your clock, your battery will never heat up significantly while it is healthy and it should stay sufficiently safe as long as there is 24hours or more between power outages (on average).
If you really want you can add a resistor in series with the battery to limit current in/out (out isn't that important):
This way it will limit to about 500mA charge current when it's at 12.5V, 1A charge current when at 11.5V and it will slowly stop charging as it closes in on the 13.5V
Of course, when power fails your battery voltage as seen by the clock will be lowered a little due to the resistor, if the clock indeed is 400mA average use it will get 0.8V less than the battery has to offer on average.
Of course it's possible your clock uses only 50mA and 300mA-ish peak when it stamps something, you could put a capacitor parallel to your clock to pick up some slack, but that's about all the advice I can write when no further specifics are given one way or another.
| improve this answer | |
  • \$\begingroup\$ Wow! Thanks for the detailed response :) So I should be alright to do this? I don't really have any resistors on hand, so I most likely will go without it. I'm not really worried about the life of the battery, as the setup will most likely change in a few years anyway. \$\endgroup\$ – user3610776 Jun 23 '15 at 21:28
  • \$\begingroup\$ @user3610776 Battery life can be measured in months, years or decades. Please note the voltages I mention. If you connect it to a 12V adapter directly your battery will be practically empty most of the time. Letting it go below 11V will put it more in the "months of lifetime" category. \$\endgroup\$ – Asmyldof Jun 23 '15 at 21:50
