Sorry for my english i'm a young french.
I want to design an audio transmitter to connect my pc to my Hi-Fi without Jack cables.
For now i just want to send a mono signal because sending a stereo seems to be too complicated and i don't need it.
The problem is that my PC's output is a stereo jack. So is it correct to merge the two signals in once, using an operational amplifier in buffer or summing ? Will the sound be ok, just suming two signals ?
Thanks
  • \$\begingroup\$ I don't think Aspect Oriented Programming is appropriate for audio signals... \$\endgroup\$
    – user16324
    Jun 25, 2015 at 9:42
You don't really need an opamp. You can do it easily enough this way:
Passive Mixer
This will sound fine although the volume level will be lower than normal -- so you will likely need to turn up the volume knob on your Hi-Fi.
    \$\begingroup\$ Suggest R3=47K pot, R4=0... \$\endgroup\$
    – user16324
    Jun 25, 2015 at 9:43
  • \$\begingroup\$ I agree with @Brian (FYI) \$\endgroup\$ Jun 25, 2015 at 10:00
  • \$\begingroup\$ @BrianDrummond why 47K pot only ? \$\endgroup\$
    – MaMba
    Jun 25, 2015 at 10:20
  • \$\begingroup\$ With R4 > 0, you can't fade right down to 0 volume. Other values will work if that doesn't matter. \$\endgroup\$
    – user16324
    Jun 25, 2015 at 10:28
  • \$\begingroup\$ @Brian But he's connecting to a Hi-Fi system so it would have final output authority, no? I'm thinking the pot is just for level adjustment to prevent saturating the Hi-Fi input. \$\endgroup\$ Jun 25, 2015 at 23:39
