I have a 24V solar system, and I want to get only 12V from the DC output.
Currently I am taking a wire from only 1 battery, but this causes unbalance in the batteries and I have to check it a lot and switch the wires to balance, also the wire is a bit long and I get a drop and when it is near or below 12V my devices stop functioning.
I thought if I can get the 24V down to 12V at the end of the wire I'd be sure to get constant voltage for the devices, and would not have to worry about the balance of the batteries and it woyld be safe since the charge controller has a deep discharge safety.
The problem is I can't use resistors or transistors (voltage regulator) due to excess heat and a transformer is not an option (nor DC to DC converters - can't get any here,) I am looking for nearly 5A of current.
So I am kind of stuck here.
How can I do this?
--EDIT--
Would making a stairs of voltage regulators be ok to use? (24V-19V-15V-12V) or would it be better if I put multiple 12V regulators from 24V?
Efficiency isn't a problem, but I don't have large heat sinks. Or is there a way to drop enough voltage so I can feed it to the 12V voltage regulator? Using a resistor will limit the current and I want to avoid that.
