First of all I am a beginner in electronics / electricity. I am currently trying to connect a coffee machine to a Raspberry Pi powered relay.
No problem with that, but as I am going to put apart and rewire a coffee machine, pretty dangerous heating device after all, I wanted to fully understand its wiring diagram beforehand.
That's where I'm stuck. This is the diagram I drew of it.
coffee machine wiring diagram
I could understand that the three pin device in the middle is a rocker switch. The thing I don't get is the use of the third pin in such a device. What if there were only two pins int the switch, and the wires connected to the upper right one were just fixed together ?
Thanks in advance!
    \$\begingroup\$ It's probably an illuminated switch so the top-right pin provides a path for the lamp and a convenient tie point for the appliance manufacturer. \$\endgroup\$ Jun 28, 2015 at 15:36
    \$\begingroup\$ Is the switch lit? \$\endgroup\$ Jun 28, 2015 at 15:36
  • \$\begingroup\$ It actually is an illuminated switch. I still don't get one thing : when the switch is lit off, i.e. the left and the top-right pin are connected, isn't there some kind of short circuit ? \$\endgroup\$
    – arnaud
    Jun 28, 2015 at 17:21
As said in the comments, it's most likely a circuit like this:
Due to this design, the light will be on, whether the thermostat is on or of (if it exists in the circuit)
So yes, shorting the right terminals would give a nice short circuit.
I've also seen switches with four terminals. Two for a pure switch, and two for a pure light.
  • \$\begingroup\$ After some thinking, and doing some more testing, I think you're right. \$\endgroup\$
    – arnaud
    Jul 4, 2015 at 20:43
The normally open side of the relay is thermostatically pulled down to the closed contact position to allow current to the hot plate / brewer element; then when the t-stat opens, the n/c side of the relay completes the circuit to the green light that lets you know that the brew is ready.
