I'm trying to build an AND gate that takes two inputs from standard 3 wire 24VDC PNP sensors and provides a 24VDC output.
I was thinking using some sort of diode resistor logic (link to circuit: http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/diodgate.html). However, I can't get this to work because when the sensors are off, the output of the sensor does not pull the inputs of the gate to ground.
What is the best / simplest way to to this?
