16
Background
I am attempting to generate some relatively high voltages (>200KV) using a system of ignition coils. This question deals with a single stage of this system which we are attempting to make generate somewhere around 40-50KV.
Originally the function generator was used to directly drive the MOSFETs, but the turn-off time was quite slow (RC curve with the function generator). Next, a nice totem-pole BJT driver was built which worked ok, but still had some issues with fall times (the rise time was great). So, we decided to buy a bunch of MCP1402 gate drivers.
Here is the schematic (C1 is the decoupling cap for the MCP1402 and is physically located close to the MCP1402):
The purpose of the transistors at the beginning is to prevent the negative voltages coming out of our function generator (it's hard to configure and easy to screw up) from reaching the MCP1402. Our fall times being sent into the MCP1402 are quite long (1-2uS) due to this crude arrangement, but there seems to be an internal hysteresis or something preventing this from causing problems. If there isn't and I'm actually destroying the driver, let me know. The datasheet doesn't have any input rise/fall time parameters.
Here is the physical layout:
Board layout
The blue wire goes to the ignition coil and the black wire goes to the ground strip on the table. The top TO92 is the PNP and the bottom TO92 is the NPN. The TO220 is the MOSFET.
Experiment
The problem that has just been plaguing this design has been a combination of ringing on the gate line and slow switch times. We've destroyed more MOSFETs and totem pole BJTs than I care to remember.
The MCP1402 seemed to have fixed some of the issues: no ringing, fast fall times; it looked perfect. Here is the gate line without the ignition coil attached (measured on the bottom of the gate pin of the MOSFET, where the green&white wire is plugged in above):
IRF840, No coil
I thought that looked great and so I plugged in the ignition coil. That spat out this garbage:
IRF840, With coil
This isn't the first time I've seen this junk on my gate line, but it is the first time I got a nice picture of it. Those voltage transients are exceeding the maximum Vgs of the IRF840.
Question
After capturing the above waveform, I quickly shut everything down. The ignition coil didn't produce any sparks, telling me that the MOSFET was having a hard time turning off in a timely fashion. My thought is that the gate was self-triggering from the ringing and cutting off our di/dt spike.
The MOSFET was incredibly warm, but after cooling down a bit it checked out with the multimeter (high impedance between gate-source & gate-drain, low impedance between drain-source after charnging gate, high impedance between drain-source after discharging gate). The driver, however, didn't fare nearly as well. I removed the MOSFET and just stuck a cap on the output. The driver didn't switch anymore and just heated up, so I believe it to be destroyed.
For reference, the inductance of the ignition coil has been measured at 9.8mH. The series resistance is about \$2\Omega\$ at DC.
  1. What in the world destroyed the driver? My thought is that the large gate transients found their way back into the gate and somehow exceeded the maximum reverse-current of 500mA.
  2. How can I suppress this ringing and keep it clean when driving the inductive load? My gate length is about 5cm. I have a selection of ferrites that I could use, but I honestly don't want to blow up another gate driver until someone can explain to me why this happened. Why doesn't it occur until I connect a highly inductive load to it?
  3. There is no reverse diode over the ignition coil primary. This was a conscious decision to avoid capping our voltage spikes, but could be misinformed. Would capping the primary voltage spike with the diode cap the secondary voltage spike at all? If not, I would gladly put one over it to avoid needing the more expensive 1200V MOSFETs. We have measured the drain-to-source voltage peaking at about 350V (~100nS resolution), but that was with a slower gate driver, so there was less di/dt.
  4. We have a selection of 1200V IGBTs that could be used (they're just sitting here on my desk). Would these have as much trouble as the MOSFETs driving this sort of load? Fairchild seems to suggest using these.
Edit:
I just did an LTSpice simulation of putting the diode over the primary to protect my MOSFET. Turns out, it defeats the purpose of the circuit. Here is the simulated secondary voltage before (left) and after (right) putting the diode across the primary:
Left: Without diode, Right: With diode
So, I can't use a protection diode it seems.
  • \$\begingroup\$ I would wager it's collapsing magnetic field from the ignition coil when you shut the fet off, as you said you made a conscious decision not to put in any protection \$\endgroup\$ Commented Jun 29, 2015 at 18:06
    \$\begingroup\$ Very well-written question. I wish most people gave at least 10% of the effort that you did! However, I expect it will soon be closed as a duplicate. You have the solution in your 3rd question. You need that diode for this very reason. \$\endgroup\$
    – bitsmack
    Commented Jun 29, 2015 at 18:08
    \$\begingroup\$ I think you are confusing the operation of a transformer with an inductor. You need to put a TVS diode across the primary that clamps the voltage to a safe level. The max output you'll be able to get on the secondary will then be limited by the TVS clamp voltage x turns ratio of the two coils. If this is not enough only then will you need to move to a higher voltage MOSFET. \$\endgroup\$
    – Jon
    Commented Jun 29, 2015 at 19:35
    \$\begingroup\$ Also if you just use a flyback diode it will clamp both the primary and secondary voltages to almost zero as you suspected. That is why you need something with a higher clamping voltage. It might be useful to read about flyback converters as this is what your circuit is. \$\endgroup\$
    – Jon
    Commented Jun 29, 2015 at 19:39
    \$\begingroup\$ Did you get this working? || Years later: Add a reverse polarity zener at FET gate-source, mounted physically as close to FET as reasonably possible. Vz slightly above max Vgate_drive_max. | Also can add a reverse Schottky diode at same location (clamps negative ringing half cycles) . Add a gate drive resistor maybe around 10 Ohms.|| THe reverse viased zener makes a vast difference when you have Miller capacitance coupling from an inductive load. \$\endgroup\$
    – Russell McMahon
    Commented Mar 6, 2021 at 8:17
6 Answers 6
19
Holy Carp! You're trying to do 10's of nsec switching on a solderless breadboard? And you don't have a flyback diode on your transformer?
If you're going to do this stuff, you've got to learn to respect fast switching and inductive parasitics. Go to a ground plane and make all your switching paths as short as possible. Also, put a 100 uF cap (tantalum for choice) across your MCP1402 to give the flyback diode something to drive besides the long leads to the battery.
You see those regular bumps on your no-load waveform? They are ~40 MHz oscillations and they are not a good sign.
    \$\begingroup\$ You cannot have a flyback diode across the transformer because that defeats the whole purpose of what a flyback converter is about. \$\endgroup\$
    Commented Jul 24, 2022 at 10:16
11
A combination of the IRF840's reverse transfer capacitance (120pF), the dv/dt of the drain voltage and the rather weak driver (MCP1402) is my best guess.
Starters, read the data sheet on the driver - it says on page 3 that the "latch-up protection withstand reverse current" is typically greater than 0.5 amps - that is a clue to why that device might be failing.
Next is Q = CV or, dq/dt = I = C dv/dt.
I'm thinking that the current through the 120pF with a big change in dv/dt on the drain is more than the driver can cope with. Just before the scope picture goes all bad I see something like 10V change in about 20ns therefore:
I = 120pF x 10V / 20ns - that is 60mA but that's just the voltage seen on the gate - it might by ten or a hundred times bigger on the drain and therefore the current might be 600mA to 6A forcing its way thru the reverse parasitic capacitor into the driver chip.
This is my suspicion anyway. I'd use a driver capable of ten amps or at least find one that can cope with a reverse current of ten amps.
  • 7
    \$\begingroup\$ As well as using a better gate drive, I'd get off the breadboard so that you can get the inductance of the driver -> gate connection down. Personally I'd build this kind of thing directly on top of copper-clad board. \$\endgroup\$
    – user1844
    Commented Jun 29, 2015 at 20:31
7
Andy's on to something, I believe, with the drain-gate capacitance.
But also: Measure what this is doing to the 12V supply. That would be an alternative path for spikes through the gate driver. Currently you're showing a single 0.1uF capacitor as decoupling, and I suspect that isn't enough. You may need a broad spectrum of decoupling from 10nF up to 100 uF or more, and if that isn't enough, consider powering the gate driver and sensitive electronics from an L-C filter and their own local decoupling.
Just place 220..470nF MKP capacitor parallel to the transformer to damp high peak voltage produced by induction coil. Now interrupted current will go to capacitor instead destroying FET.
This is made in all CRT TV's and monitors horizontal output stage.
Your Gate driver is being destroyed because of voltage spikes when MOSFET turns off..
Check this out: Snubbers
In case others come across your question.
Using inductive kickback for high voltage generation is a bad idea even in cars: those things are bad RF noise sources. There's a reason why modern cars use individual coil packs for each spark plug, and why those are often buried in the aluminum head covers: it's the smallest possible current loop, has inherent shielding, and can be quite RF-quiet.
If you want to generate 200kV, standard ignition coils and inductive kickback and fast edges are only worth contemplating if everything including the load is in a Faraday cage or a metal shield. It will never ever pass any EMC testing otherwise, and its prolonged use is illegal.
You want to use a custom-wound transformer designed for 50kHz or thereabouts, oil-insulated. It'll be quiet as long as you don't produce sparks with it. Once you get it arcing randomly, you're back to a broadband RF interference source.
