analog signal can b easily made by using PWM in micrcontroller but it is not a real analog signal. please tell me how can i convert PWM into real analog signal
5\$\begingroup\$ Low Pass Filter. \$\endgroup\$– Eugene Sh.Jun 30, 2015 at 17:58
1\$\begingroup\$ How accurate and how stable? \$\endgroup\$– Andy akaJun 30, 2015 at 18:05
\$\begingroup\$ How quick PWM and what signal bandwidth do you require? \$\endgroup\$– DzardaJun 30, 2015 at 18:11
\$\begingroup\$ actully i want to make air mouse using accelerometer and Arduino for this i modified my joystick. I removed the potentiometer and give signal from Arduino which use PWM according to accelerometer signal. but it is not a analog signal so computer curser vibrate \$\endgroup\$– Manish SutharJun 30, 2015 at 18:17
1\$\begingroup\$ No attempt to search for relevant information. Question should be closed. \$\endgroup\$– Leon HellerJun 30, 2015 at 19:11
1 Answer
Did you actually attempt to search, at all?:
OR
On instructables if you want it simpler and less broadly explained.
OR
The options are limitless for getting this exact information.
