Having a bit of trouble finding the right information on google, and I'm worried I might fry some cables so I thought it best to ask some far more knowledgable than myself.
I want to connect 2 or more devices, giving them 5V/2A plus networking between them.
I figured to do so with the least amount of cables, Passive POE would be a good choice. The distance isn't far, probably maximum 20ft, as each device will be somewhere in a car, connected in to the boot/trunk area.
I'm looking at splitters and injectors, from what I've read its not as simple as just injecting 5v and it'll work? I have to worry about loss and also heat.
So my questions are, what is the best way to get 5V with max 2A current to the destinations? Do I need to send higher voltage to ensure it doesn't drop below 5, then use a regulator to ensure 5V? If I do that, the power will also be higher therefore more heat, is that ok?
Studying Wikipedia page I've read "Category 5 cable uses 24 AWG conductors, which can safely carry 360 mA at 50 V according to the latest TIA ruling"
50v * 0.36a = 18W, so if I were to send 9v * 2a = 18W. Then I could use a regulator to drop the ~9V(allowing for loss) down to 5V. Does that sound reasonable?
Many thanks
