I have edited the question to make it easier to explain what I am asking for.To make it clear, I have deleted the part with the 555 timer. I have a question regarding the following:
I know that once the battery is connected, the capacitor is going to have a varying voltage across it until it will be fully charged, reaching 7 volts. During this time, what will happen to the other two branches (the ones with the two resistors) ? According to the law of parallel connections, the voltage measured across any component will be the same, equal with the one of the battery. As the cap. charges, will the other branches have a varying voltage across them too, or will they have a potential difference of 7 volts from the beginning across them, as the capacitor?
