Here is the schematic that I'm working with: http://www.circuitsonline.net/schakelingen/59/audio/led-vu-meter.html
The LED attached to pin 10 is always on. Is there anyway I could get this so that all 10 work as part of the VU-meter?
That's odd. Are you sure it's the LED on pin 10, and not the one on the other end, on pin 1?
Take a look at page 7 of the datasheet. There's a resistor ladder network creating a series of voltages to compare to, starting with the reference voltage for the LED on pin 10. If the input voltage is higher than this \$V_{REF}\$ the output of the comparator will go low, and the LED will be on. For the other levels the comparator uses a lower voltage each time. So if only the LED on pin 10 is on it would mean that the input voltage is higher than the reference, but NOT higher than the other comparison voltages, which are lower. This just doesn't make sense.
It would make sense if it were the LED on pin 1, then it could be that you have a DC offset in your signal, which is higher than the first threshold.
edit
I did notice that you use the LM3915 in dot mode (which I commented as odd for a VU-meter; you would rather use bar graph mode there), but I didn't connect this to my previous observation. Of course you'll see only one LED in dot mode! If the LED on pin 10 is the only LED you can get lit your input signal may be too high. Try to short the input to ground, and, alternatively, connect pin 9 to pin 3 and see what happens. If my hunch about a too high level is correct you should see all LED on.
Summary:
The data sheet contains extra data which should be relevant.
Knowing the exact circuit you are using will assist. How is pin9 connected? What supply voltage are you using? (Both possibly relevant to the result).
Control of the state of pin 10 / LED10 is complicated and you need to read the LM3915 data sheet carefully to see how it is controlled. There are various parts of the datasheet that may be relevant. There are a number of things that may be affecting what is happening. You need to read the relevant parts of the data sheet and see how what you are doing compares to what it says.
Here are some references to parts of the datasheet that may be relevant. You need to work through these and see which if any is.
Note that LED10 is used as part of chaining and you may be seeing permanent device overload. This seems unlikely but may be a factor.
The level on pin 9 (which is open circuit in your diagram) is relevant. This pin may do different things depending on how it is connected. See note 5 on page 4.
See block diagram page 7 and note pins 6 & 7 relationship.
See mode pin description pages 8 & 9.
Also see bottom of page 9 re possible oscillation.
Understand the above. Try appropriate changes. Report back.
