I want to make a plane for my supply on my PCB and a plane for my MCU to isolate the MCU from the power supply noise.
I found this article in Altium designer resource:
But it isn't clear how the split plane tool work. Can someone explain it in a different manner?
[EDIT]
This is a picture how I see the planes: enter image description here
  • \$\begingroup\$ Which particular task did you have trouble with? \$\endgroup\$
    – The Photon
    Commented Jul 6, 2015 at 19:13
  • \$\begingroup\$ Defining the region, I can't properly set the internal plane. \$\endgroup\$
    – MathieuL
    Commented Jul 6, 2015 at 19:16
  • \$\begingroup\$ easy.. just draw a closed shape and double click it to tie a net \$\endgroup\$
    – hassan789
    Commented Jul 6, 2015 at 19:20
  • \$\begingroup\$ With the polygon pour tool? \$\endgroup\$
    – MathieuL
    Commented Jul 6, 2015 at 19:24
  • \$\begingroup\$ Yes, with the polygon pour tool I think it is possible. \$\endgroup\$ Commented Jul 7, 2015 at 13:59
Click on Place Polygon Plane ( enter image description here ). On the dialog, in the Net Options select the specific net to which your component is connected.
Then draw the desired shape for your polygon(s).
