Below is a picture of a battery shell for a NiMH circuit for a power assist wheelchair battery. I'm taking a guess that each of the 20 batteries is 1.2V because the entire circuit is 24V. These are rechargeable.
I'd like to convert this circuit to the same voltage (24V) and same capacity (3Ah).
First, is this possible given the space you see in this wheelchair battery shell, and the circuit board in the pictures?
Second, what are the material requirements to be able to convert this circuit from NiMH to Li-Ion and the type of charger as well? What materials will I need to solder/weld the materials together, etc.. for the actual labor? I'm an electrical novice, so please ask me more questions (as comments) and I'll do my best to answer.
Note: right click image and open in a new window to make it larger!
  • \$\begingroup\$ Reference: See "About Rechargeable Battery" batteryspace.com/batteryknowledge.aspx \$\endgroup\$
    – MacGyver
    Jul 8 '15 at 5:27
    \$\begingroup\$ Be aware that Li-ion batteries have a nasty habit of catching fire if mistreated. Always use a proper Li-ion battery charger designed to charge the battery pack you end up using. \$\endgroup\$
    – Simon B
    Jul 8 '15 at 9:17
  • \$\begingroup\$ Reference: batteries seem to be welded in just the right orientation. When I lifted them out of the blue shell, they all came up together because they were all connected with those little tabs between each battery. Dimensions of each cell is 1-11/16" (height) and 15/16" (diameter) \$\endgroup\$
    – MacGyver
    Jul 8 '15 at 16:31
  • \$\begingroup\$ Reference for NiMH controller: pdf1.alldatasheet.com/datasheet-pdf/view/26770/TI/BQ2013H/… \$\endgroup\$
    – MacGyver
    Jul 8 '15 at 16:52
  • \$\begingroup\$ Reference to design and order PCB: pad2pad.com \$\endgroup\$
    – MacGyver
    Jul 8 '15 at 21:17
Li-ion batteries put out 3.7V per cell, while NiMH generate 1.2V. So, 20 cells at 1.2 V generate 24V. With Li-ion you will need 24/3.7 = 6.5(!) cells. This is somewhat difficult to solve... Maybe the chair can accept 7 cells? That would be the equivalent of 25.9V - a bit much, though 8% might be acceptable.
If you have the space to fit more cells - maybe the same quantity as before (20 cells), you could include a switching converter to lower the voltage to the original 24V, and make better use of the space, and have more capacity.
The pack would then have 20*3.7 = 74V, which should be convertible to 24V. But you would need to look for a charger which works at 74V which probably would not be so easy to find commercially. There are plenty of circuits for chargers around. Don't skimp - find a good circuit to avoid overheating problems!
You could also think about two sets of 7 in parallel - or 3 if you can fit the extra cell. You will have 21 cells total. More info on paralleling packs is available here.
The BQ2013H IC on the board is a controller which is for high-discharge battery packs, but is only for NiCd, NiMH or lead acid packs. It doesn't seem to support Li-Ion packs. So there is some work to be done there.
I looked up equivalents for Li-Ion, and Texas Instruments has a new one (bq34x100) which shows promise. You'll still have to redesign the board though.
  • \$\begingroup\$ Do you see those 5 little white LED lights on the 2nd picture from the left? Those light up when the battery is charging and show how much charge there is when the battery is in use (when the motor is drawing from the battery) via that copper circle device. So the circuit board is configured for the charger, I think. Do you think the circuit board need to be switched out if I use a different type of circuit? \$\endgroup\$
    – MacGyver
    Jul 8 '15 at 5:04
    \$\begingroup\$ The indicator seems to have a control chip on the other side. If you can check the markings? If it's a microcontroller, then things could get complicated. The software might be NiMH-specific. \$\endgroup\$
    – jcoppens
    Jul 8 '15 at 14:20
  • \$\begingroup\$ In picture #2, there is a little black rectangle next to the 5 LED lights. That reads PH42 on line 1, and GN0GT (or 6n06T since it's so tiny I can't tell) on line 2. In picture #5 (green circuit board flipped over), there is a larger black rectangle, which reads bq2013H on line 1, and 38ZL03WA514 on line 2. I'm guessing you are referring to that black rectangle device in picture #5 per your "markings" comment? Is that the microcontroller? \$\endgroup\$
    – MacGyver
    Jul 8 '15 at 16:08
  • \$\begingroup\$ It's hard to tell if it reads bq2013H or bg2013H \$\endgroup\$
    – MacGyver
    Jul 8 '15 at 16:11
    \$\begingroup\$ Ok. It's a bq2013H. I've updated the answer above to keep all info together. \$\endgroup\$
    – jcoppens
    Jul 8 '15 at 16:25
