I am using a circuit to drive high voltage display tubes (170V DC, 3mA).
Currently, the tubes get switched by an arduino. The output pin is hooked up to a MMBT42 transistor and a 10kOhm base resistor.
I want to use a PCB, with 80 of those lamps. So I need at least 80 transistors and 80 resistors, which is is a lot of work to solder the parts.
Now I wonder, if I could replace the resistor/transistor with this mosfet because the mosfet does not need a resistor.
This BSS131 is a logic-level Mosfet, according to the datasheet.
Would this suit for my application?
