I am new to electrical engineering and I would like to build simple circuit with potentiometer as voltage regulator.
I have simple circuit, as you can see in attached picture below.
I have 12V/1000 mA DC source connected via potentiometer to LED strip (unfortunately I don't know the resistance of this component, strip is about 1.5m long - type 5050 if it will help somehow)
I would like to know what kind of POT should I use to regulate source to range 6 - 12V. At the moment I have chosen 1k Ohm POT and it dims LED strip only in first 10% of range then nothing happens at all because strip barelly shine.
