What is the name/description for the test point pins on this board?
I've tried Digikey for all combination of binding post, test pins et, but no luck.
These are through hole parts, height ~6mm, pin dia 1mm.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityWhat is the name/description for the test point pins on this board?
I have found this one very similar to the test point. it will be impossible and not worth the time to search by only image as reference. This link gives a lot of similar looking parts you are looking for. Please feel free to choose..
In Digikey's hierarchy look for:
Product Index > Connectors, Interconnects > Terminals - PC Pin, Single Post Connectors
For example, this one (P/N 3137-1-00-21-00-00-08-0):
There are many other types! Depends on the exact dimensions you need.
Below testPoints may suits your requirement
1 MULTICOMP TEST-27 TEST PIN, PCB, 1.5MM
2 WEARNES CAMBION 460-2970-02-03-00.. TEST POINT, PCB
3 MULTICOMP TEST-4 TEST PIN, PCB, 0.95MM
4 MULTICOMP TEST-22 TEST PIN, PCB, 1.0MM
Definitely those are test points. There are many kinds, not necessarily you will find the specific part on digikey.
These are often referred to as turret connectors or turret lugs.
