-2
I have a transformer with multiple taps on the secondary coil deliverin many different voltages and I want to know if I blow something up when I convert the AC of the transformer to DC with bridge rectifiers and then connet the ground.
closed as unclear what you're asking by Matt Young, Leon Heller, Daniel Grillo, PeterJ, Spehro Pefhany Jul 12 '15 at 22:48
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • 4
    \$\begingroup\$ Go edit your question, press Ctrl+M, and draw a schematic of what you propose doing. The textual description is way to hand wavey. \$\endgroup\$ – Matt Young Jul 10 '15 at 16:40
Unless the secondaries are made with isolated windings, if you try and add 2 or more bridge rectifiers you will find that commoning up the "ground" output side of the bridges will short out the windings. There are many variations of secondaries with taps but I'm yet to see one that doesn't ALWAYS short out the winding in one direction of current flow.
See this Dave Tweed answer
Also see this answer
