I'm making a frequency divider and the easiest way is to use a johnon's counter with D flip flop. The point is that if I make the clk start high, the counter has undefined output, while if I make the clk start low, it all should be ok.
Code of ring johnson's counter ("divide_by is unusued at the moment"):
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity double_period is
port(
clk : in std_logic;
--i 3 bit seguenti rappresentano 8 stati (stato 0 : divisione frequenza per 2, stato 1: divione per 4, stato 3 : divione per 6, etc...)
divide_by : in std_logic_vector(2 downto 0);
out_clk : out std_logic
end double_period;
architecture double_period_behaviour of double_period is
signal filoFlottante : std_logic;
component ffd is
port(
clk : in std_logic;
din : in std_logic;
dout : out std_logic
end component;
signal dInternal : std_logic_vector(8 downto 0);
signal dFirst : std_logic;
begin
dFirst <= not(dInternal(2));
f0 : ffd port map(clk, dFirst, dInternal(0));
f1 : ffd port map(clk, dInternal(0), dInternal(1));
f2 : ffd port map(clk, dInternal(1), dInternal(2));
--f3 : ffd port map(clk, dInternal(2), dInternal(3));
--f4 : ffd port map(clk, dInternal(3), dInternal(4));
--f5 : ffd port map(clk, dInternal(4), dInternal(5));
--f6 : ffd port map(clk, dInternal(5), dInternal(6));
--f7 : ffd port map(clk, dInternal(6), dInternal(7));
--f8 : ffd port map(clk, dInternal(7), dInternal(8));
out_clk <= dInternal(0);
end double_period_behaviour;
D FLIP FLOP CODE:
library ieee;
entity ffd is
port(
clk : in std_logic;
din : in std_logic;
end ffd;
architecture ffd_behaviour of ffd is
begin
process(clk)
variable qvar : std_logic := '0';
begin
if clk'event and clk='1' then
qvar := din;
end if;
dout <= qvar;
end process;
end ffd_behaviour;
The following is the TESTBENCH:
library ieee;
entity double_periodTB is
end double_periodTB;
architecture double_periodTB_behaviour of double_periodTB is
component double_period is
port(
clk : in std_logic;
end component;
signal clk : std_logic;
signal out_clk : std_logic;
signal divide_by : std_logic_vector(2 downto 0);
begin
process
begin
clk <= '1'; wait for 10 ns;
clk <= '0'; wait for 10 ns;
end process;
process
begin
divide_by(0) <= '0'; wait for 10 ns;
end process;
process
begin
divide_by(1) <= '0'; wait for 10 ns;
end process;
process
begin
divide_by(2) <= '0'; wait for 10 ns;
end process;
sg : double_period port map(clk, divide_by, out_clk);
end double_periodTB_behaviour;
"DIVIDE_BY" IS UNUSUED AT THE MOMENT!!!!
