OK so I've been asking around and reading how to connect ground pins to ground. Some said create vias to the ground planes. But should I do that for every pin? Because sometimes when I create via to each component then route their connection on the ground plane, the net line doesn't disappear all the time.
Then other sources say create polygon pours after the connection is done. Sounds fine.
Honestly I'm a bit confused, can anyone just clarify how to route ground connections? I have tried connecting initially but I feel that something is not right about it.
Note that the ground pins of each of the boxes are connected
  • \$\begingroup\$ What is your design intent? Fewer vias is better for manufacturing but might be worse electrically and it might be better- only you know your circuit design. I don't know what the red trace in the RH box above is supposed to be doing - it's not on the same layer as the SMT parts and the via is obviously already connected to the through-hole pad through the plane. I also don't see a blue trace to the vias. Can't you use smaller vias and maybe space them off a bit further?- they look enormous compared to those 0402? parts. Rubber band lines should disappear if all the net names are correct. \$\endgroup\$ Commented Jul 12, 2015 at 13:58
Through-hole pads don't need another via --- they already extend through the board to all layers.
For SMT, one via per pad is a starting point. Each component probably has its own current draw so you want to have enough vias to accomodate that. But you might find cases where it's not needed. For example, a bypass capacitor next and the power pin for an IC placed near each other probably can share one via.
Generally I hide the ratsnest lines for power and ground pins during the initial part of the design. Then they don't clutter things up while you're routing the signals. Once signals are routed, turn the power and ground net ratsnest back on. As you connect each pad to the planes, you should see one netline disappear. It might not be the one you expect, but by the time you connect all the pads to the planes, they should all be gone.
Altium distinguishes polygon pours from plane layers.
Polygons are positive features on positive (signal) layers, that fill large (or small) areas.
Plane layers are negative layers where copper is present on the entire surface, except where features are defined. If you make a polygon on a plane layer, you will produce a region with no copper, not a region with copper.
Making polygons last is mainly a convenience: Redrawing polygons can take a long time, and you don't want to be waiting for it to happen all the time during your design, so you draw your polygons last to avoid that inconvenience during most of the design process.
  • \$\begingroup\$ Altium's polygon engine is nice but MAN is it needlessly slow. \$\endgroup\$
    – akohlsmith
    Commented Jul 12, 2015 at 15:48
    \$\begingroup\$ "Shelving" polygons was the best feature added to Altium in the last 15 years. \$\endgroup\$
    – The Photon
    Commented Jul 12, 2015 at 15:49
    \$\begingroup\$ You DO NOT route connections on the ground plane - anything you draw on the ground plane ends up as "no copper" - a hole in the plane. \$\endgroup\$ Commented Jul 12, 2015 at 15:56
