-2
I am hoping to attempt to fix my childrens ride on electric car as the power supply was left charging and has cracked / broken (see pics).
Original Broken Power Supply Connector
I am completely new to electronics, but was hoping to replace the power supply and get the car working again.
The power supply seems to have a non-standard connector and I cannot seem to source a replacement on the internet so the only option "I can see" is to replace the power supply and solder / re-attach the connector to it, hence this question.
I have measured the voltage across the car battery and getting about 13 volts so can I assume that this has not been damaged?
I have looked at a few articles / videos such as -
https://superuser.com/questions/166876/can-i-patch-my-laptop-power-cable
Is it OK to solder a power cord?
https://www.youtube.com/watch?v=gTAUupMxT1U
But the over-riding theme seems to be its fine to DONT MESS ABOUT unless you know what you are doing?
I am in the UK.
I was hoping that someone who knows what they are doing could describe if / how they would attempt to repair this (maybe there is an alternate way or the connector is not so non-standard). They may also describe how dangerous is could be if done wrong?
I can at least then go forward knowing I can pay someone to complete the repair if I am not comfortable doing it myself.
EDIT: As this question has been put "on hold", here are some original notes that I did not post but probably should have to show where I had got to, but on reading the link again, think I would have to know how to design a power supply before asking how to repair one? yet individual questions regarding parts of the steps to repair on are OK on this site -
For the record, from those others links here is what I would do if I wasn’t concerned about safety.
  • Cut the connector end off the broken adaptor, cut the end of the new replacement adaptor.
  • From the picture, would separate the 2 wires.
  • Strip wires tidily.
  • Twine them (people seem to think this is better than just touching and solder).
  • Solder them
  • Heat shrink wrap each wire
  • Heat shrink wrap the external wire around the join to keep tidy.
  • Test the adaptor without letting it out of sight (but to be honest how would I know it was OK? I will check for heat in wire etc).
closed as off-topic by Leon Heller, PeterJ, Ricardo, Daniel Grillo, brhans Jul 14 '15 at 16:39
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the repair of consumer electronics, appliances, or other devices must involve specific troubleshooting steps and demonstrate a good understanding of the underlying design of the device being repaired. See also: Is asking on how to fix a faulty circuit on topic?" – Leon Heller, PeterJ, Ricardo, Daniel Grillo, brhans
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Really, if it looks like that, throw it away, this is an accident waiting to happen. \$\endgroup\$ – PlasmaHH Jul 13 '15 at 15:45
  • \$\begingroup\$ @PlasmaHH, I only intend to use the connector bit on a newly purchased supply with equivalent specs? still a no go? thanks \$\endgroup\$ – WickedW Jul 13 '15 at 15:48
    \$\begingroup\$ That looks like an american 4-way trailer connector. en.wikipedia.org/wiki/Trailer_Connector/North_America \$\endgroup\$ – brhans Jul 13 '15 at 15:48
  • \$\begingroup\$ @WickedW: Something has caused it to melt, and that is certainly not only depending on the quality of the power supply. \$\endgroup\$ – PlasmaHH Jul 13 '15 at 15:52
  • \$\begingroup\$ @PlasmaHH good point, I left it plugged in for a week or so and the case ended up cracking. \$\endgroup\$ – WickedW Jul 13 '15 at 15:58
All you would need to do is note down the polarity of the connector, cut the wire off the old supply and wire it to a new 12v DC supply rated for the 1A output Making sure the polarity is correct to avoid burning out any reverse polarity protection diodes.
  • \$\begingroup\$ thanks @B-TECH, how would I note the polarity of the connector? do I take apart the existing supply and check how it connects internally? \$\endgroup\$ – WickedW Jul 13 '15 at 16:12
    \$\begingroup\$ @WickedW there is a drawing on the front of the power brick. The three metal prongs are redundantly connected to + and the hooded prong is connected to -. \$\endgroup\$ – crasic Jul 13 '15 at 20:30
  • \$\begingroup\$ Thanks to the people who took the time to reply, I went ahead with repair, I used the markings on each wire to note polarity for both adaptors wires, I also measured polarity using multimeter to be sure, I then soldered the 4 way connector onto the new adaptor and insulated, I did my best to check all was OK, and the kids are now driving around the back garden in the car. \$\endgroup\$ – WickedW Jul 17 '15 at 6:54
