I have been trying to find the Absolute value of an integer which is designated to Verilog core using Xilinx C running on Microblaze, what i have seen is that Verilog treats the negative number as a positive number.
I have tried all data types : signed int, int, Xuint32.
My c code is:
signed int data,value;
data=-20;value=0;
putfsl(data,0);
getfsl(value,0);
signed int data1,value1;
data=20;value=0;
putfsl(data1,0);
getfsl(value1,0);
After getting the values of variables I printed them on Hyperterminal.
On my Verilog side the code was:
out <=(in<0)?-in:in;
I also tried this code but results were similar
if(in<0)
   out=-in;
else
   out=in;
Kindly help me out!
I have also tried other data types and changed parameters but results have not worked out to be I always get the same number I input i.e
in<0
statement is not being true, I also tried in<=0.
(Disclaimer: I'm not a Verilogger - its signed arithmetic foibles being one of the reasons why not :)
Prior to Verilog-2001 all vector arithmetic in Verilog was unsigned.
In Verilog-2001 you can explicitly call for signed arithmetic, so I think you'll need to cast your in:
if ($signed(in) < 0)
 out = -$signed(in);
else
 out = in;
Reading matter which may be of interest:
Signed arithmetic in Verilog-2001 - Opportunities and Hazards
  • \$\begingroup\$ Thanks AloT!! It really worked, i had spent like two days solving this very problem.Really appreciate as i had thoroughly searched on the internet, and failed to find any answer. \$\endgroup\$ – aibk01 Aug 11 '11 at 16:08
