I am trying to "light" all the net labels that are connected together , to see if everything is right.
So for example if one pin of a resistor called "R_A" and another pin on some other chip called "R_A" , i would like to push something in Eagle to see both of them(and all other labels with the same name) in some bold color/light .
How would you do that in Eagle ?
Thanks a lot .
6
Use show and double click on the Net/Wire, then all pins will be red, the names black and the nets will be light green
  • \$\begingroup\$ Great thanks it worked although tou barely see it. Is there a way to check errors also in my circuit(not pcb) ? \$\endgroup\$
    – Curnelious
    Jul 19, 2015 at 12:01
  • \$\begingroup\$ Also ,why its not working between pages?? If i show in page 1 connection i wouldnt see it in page 2.. \$\endgroup\$
    – Curnelious
    Jul 19, 2015 at 12:11
    \$\begingroup\$ Chechking if its right would work with either ERC or you looking if something is connected wrong. Seems like its generally not working between pages, sorry :C \$\endgroup\$ Jul 19, 2015 at 12:15
    \$\begingroup\$ You can also type show net into the command box (where 'net' is the name of the net you want to show) \$\endgroup\$ Jul 19, 2015 at 12:25
    \$\begingroup\$ also use show ~ netname to get all pages (case insensitive) \$\endgroup\$
    – logic0
    May 1, 2022 at 22:13
Go to Options > Set... > colors > high contrasts to make the connections pop out more
