#define POKE(addr, val) (*(volatile unsigned int *)(addr) = (val))
#define POKE_AND(addr, val) (*(volatile unsigned int *)(addr) &= (val))
#define POKE_OR(addr, val) (*(volatile unsigned int *)(addr) |= (val))
I dont understand what does it mean
for example when i call function
ulVal  = PEEK(NETX_IO_CFG);
where NETX_IO_CFG
#define NETX_IO_CFG     0x00100004U
    \$\begingroup\$ Which package is this in? I want to buy the writer a beer for using the terms peek and poke! \$\endgroup\$ – Asmyldof Jul 20 '15 at 6:45
  • \$\begingroup\$ in netx500 micricontroller project \$\endgroup\$ – user3826752 Jul 20 '15 at 6:48
  • \$\begingroup\$ Peek and poke were used in Basic for the Commodore Pet (6502 processor) for accessing individual memory RAM locations \$\endgroup\$ – Chu Jul 20 '15 at 16:37
define has two practices it can be used to define a constant:
#define PI (3.14)
or it can be used to define macros(somehow look like functions) and it's inlined directly into the code, so there isn't any function call overhead as in :
#define MAX(a, b) ((a) > (b) ? (a) : (b))
in this case,
is a macro(like a function) to store val into the address addr by using the concept of pointers
https://en.wikipedia.org/wiki/Pointer_(computer_programming)
    \$\begingroup\$ Also see PEEK and POKE for some historical reference regarding those terms. \$\endgroup\$ – kkrambo Jul 20 '15 at 13:09
here is being used the way to declare a macro in C compilers. the compiler changes the expression POKE(addr, val) by *(volatile unsigned int *)(addr) = (val) in code which means to assign variable val to derreferenced and casted((volatile unsigned int *)) pointer addr, so on for the remains. Sorry, English is not my first idiom.
