I am trying to make a smart power socket using Arduino.
The socket should power even high power equipments at 230 Volt 50hz through a relay. I want my arduino to analyse the amount of current taken by the equipment, so that when there is a sudden drop in current taken by the equipment , the arduino will switch off the relay.
The idea is that when a charger finish charging a device ,there will be drop in current taken and so it can be turned off.Or in case of a TV when it is switched off by remote there will be a drop in current and the relay will switch off to conserve energy.
I know how t o connect and program but don't know how to detect the drop in current and send signal to aruino. It will also be fine if I can linearly decrease current and voltage so that it is compatible with arduino.
