Buzzer 1 Buzzer 2
(Click on images for larger view.)
The AC indoor unit I own has an 85dB, 2kHz piezo-buzzer on the PCB. I find it unnecessarily loud, so after coming across this question I filled its hole with blu-tack. This muffled the sound it produces, but not as much as I expected. I'm willing to try hot glue in the future.
What I'd like to know is whether it is safe to remove the piezo-buzzer from the circuit. If not, what can I replace it with?
Buzzer 5 Buzzer 6
The schematic diagram and PCB diagram above are taken from the unit's service manual (the location of the buzzer is BZ61). Bearing in mind I don't have much of a background in electronics, and have little experience fiddling with PCB's (sorry!), is there anything useful I can safely assume from these diagrams?
    \$\begingroup\$ Just clipping the metal wire leading into the buzzer shown in the top picture should do. Then bend the leads away. This way you can re-hook it up if necessary. No harm will be done. \$\endgroup\$
    – ACD
    Jul 24, 2015 at 12:43
You can completely remove it without any substitution. The Transistors are fully biased in the system by resistors already.
In fact, they have slightly over-engineered it, if you ask me, but these days I'd say I'm pleasantly surprised by such things.
You/it should not even notice the removal by a change in power required for the buzzer circuit to any noticeable extend.
  • \$\begingroup\$ Wow ... lets add a few more transistors - just in case. :) \$\endgroup\$
    – brhans
    Jul 24, 2015 at 13:12
    \$\begingroup\$ @brhans certainly the first time I saw an appliance use a piezo with a balanced amplifier layout, heck I've seen shoddier speaker set-ups. \$\endgroup\$
    – Asmyldof
    Jul 24, 2015 at 18:41
