I have an equipment which draws 550W at a constant level, no peaks. I want to power this unit with solar cells only during the day when there is light using a simple car battery. Because I don't want to invest in a expensive battery I put it down to run only during the day. How can I calculate the exact cell power I need and the controller. Battery is 63Ah/12V, would it be enough ?
edit: Sorry, forgot to mention: 1. device run on 220V and i'll use power converter from 12 to 220. 2. I'll run the equipment as long as there is sunlight, summer hours are average is 10hrs a day winter average is 7hrs Thanks,
