White noise is being passed through a voltage follower, then filtered through a simple first order low pass RC circuit (C=0.5 micro Farad, varying resistance between 2k-10k, ohm depending on RC value tested). This is then recorded using an A2D device. I am then calculating the power spectra using the following python code applied to the acquired raw data:
def FFTF2(raw_data):
    result = abs(np.fft.fft(raw_data)*np.conj(np.fft.fft(raw_data)))
    return result[0:(len(result)/2)]
The result is the following:
RC=1ms
This is at an RC of 1ms. As you can see the very low frequencies are missing power. Its as if the signal is going through a bandpass filter. The effect is not as noticeable at higher RC values.
This is the unfiltered noise:
unfiltered noise
If I use a different op amp in the voltage follower circuit I get the following at different RC values:
RC of 5ms:
RC of 2.5ms:
RC of 1ms:
What could be causing this "cutting" at the lowest frequencies? Does the power spectra of this filtered noise look "ok", or should the decay be smoother?
  • \$\begingroup\$ Two ideas off the top of my head: 1) it's random (can you take more data and see if the effect persists?); 2) there's some current leakage through your capacitor (just a hunch that this would cause you to lose power at low frequencies). \$\endgroup\$
    – tok3rat0r
    Jul 24, 2015 at 14:19
  • \$\begingroup\$ This question might receive better attention, a better answer in the Electrical Engineering stack \$\endgroup\$
    – docscience
    Jul 24, 2015 at 14:21
  • \$\begingroup\$ @tok3rat0r: 1) The sample sets used are 100,000 samples @ 10,000 a second. I have tested maybe 50+ sample sets, all show this problem to some varying degree, depending on the op amp used in the voltage follower. 2) I have tested 2 different RC circuits, both show this issue. \$\endgroup\$
    – gline
    Jul 24, 2015 at 14:26
  • \$\begingroup\$ @docscience: Maybe it could be moved there if the moderators think it would be better there? I wasn't sure where to post it. \$\endgroup\$
    – gline
    Jul 24, 2015 at 14:28
  • \$\begingroup\$ OK, so most likely to be some non-ideal component behaviour (finite resistance of capacitor or capacitance of resistor). As @docscience says, probably a better fit for EESE. \$\endgroup\$
    – tok3rat0r
    Jul 24, 2015 at 14:29
There are a few things that could be happening to be honest.
1) Your Op Amp is a real Op Amp. As such, it has limits for what type of loads it can drive (They aren't all unity stable, they aren't all capable of driving capacitive or inductive loads, etc.)
2) Your ADC input impedance is messing up your "power delivered." In Electrical circuits, loads have an effect on the filter frequencies. ADC's also aren't really known for having resistive inputs.
Personally, I think it's the second one, but it doesn't really matter 'cause you solve both the same way. Move the filter to before the Voltage buffer (follower) and see if that fixes the problem. It should look like this:
