When you listen to people wiring up a DC circuit they seem to mumble about the electricity flowing from positive to negative. However in school I was always taught that DC electricity flowed from negative to positive.
I was googling for this and didn't see the definitive Stack Exchange post. Anything I read either isn't clear about this or is too complicated for me to understand.
Can someone please explain this to me like I'm 5? It seems like one of those things where both sides are right but there is a subtle difference that is difficult to communicate.
The answers you were given and what you were taught in school are all correct. When electric current was first discovered people didn't know which way to choose and they assumed that it flows from positive to negative. Later it was proved that it is the other way, electrons seeking the positive terminal. Despite this new discovery, nobody wanted to change the way of looking at this flow, so it's still considered to be from + to - for two reasons:
-The same calculations, laws and formulas work for both ways
-There were already many books and documents based on this concept and everyone was already used to it. Since it wouldn't affect the computations and the rest, there was no need to change it.
  • \$\begingroup\$ Note that the "flow" from positive to negative is much faster than the "flow" from negative to positive. The positive->negative flow is near the speed of light (we can see this because lights almost instantly turn on when we hit the wall switch) but the flow from negative to positive is roughly 1 metre per hour. It's like traffic jam - the gaps between cars move backwards through traffic much faster than the cars move forwards \$\endgroup\$ – slebetman Jan 30 '19 at 11:04
    \$\begingroup\$ @slebetman Yes, but this may be confusing for some readers. The positive->negative flow is the Electro-magnetic power flowing out of the battery or the generator: yes, this power travels at almost the speed of light (2/3 of it with chopper lines). Instead, the negative->positive flow is the actual flow of electrons, which do not move at the speed of light. As correctly pointed out, their speed is some centimeter per second. They are not so fast. \$\endgroup\$ – BowPark Jan 30 '19 at 12:13
  • \$\begingroup\$ @BowPark It's not merely power. There is something physical that moves in that direction at the speed of light - holes left behind by the electrons. Any confusion can be eliminated by asking the reader to observe gaps left behind by cars in a traffic jam (unless you live somewhere where traffic jams don't exist) \$\endgroup\$ – slebetman Jan 31 '19 at 11:56
In the beginning, before anybody knew about electrons, Benjamin Franklin postulated (guessed) that "electricity", whatever it was, moved from the arbitrarily named positive pole of a battery to the negative, in order to do its work.
We now know better, and when it matters it's taken into account.
For most work it doesn't matter, so his convention is still followed, and charge flowing from positive to negative is called "conventional current".
First, we have some issues with the terminology. "Electricity" is not really all that well defined term. I'm not aware of any measurement units that measure electricity or anything like that, so I'll just avoid talking about it.
Instead, I'll talk a little bit about physical quantities we know. The interesting ones here are electrical current, electrical charge and electrical potential.
Current is defined by amount of electrical charge that goes through some surface in a unit of time.
So let's take a look at this image here: electrical current through a conductor
The black shape is some material through which electrical charge can somehow flow. The red disk is the surface through which the charge is flowing. This is our "counter". So when we say that we have current of X amperes, that means that we have flow of one coulomb of charge through the surface in one second. So far so good.
Now comes the part with the "electron flow" and the "conventional current" flow. You have to keep in mind, back then when our first scientists were researching electrical current intensity, it wasn't all that well known what this current thing is and what it's made of. People didn't know that it was electrons that carry the charge. They did know that it was something there, but what exactly it was, that wasn't very clear.
So what they did was simple: They studied the macroscopic model. That was the practical thing to do. If you want to use a battery, you don't really need to know how many electrons can go from one side to another. It's good if you do, but that's not practical knowledge. Instead, it would be much better to know that it can supply say 3 amperes for two hours until discharged.
There was also the development of notion of "electrical potential". It was logical to imagine that our current will flow from places of higher potential into places of lower potential, so that's how we defined the direction of current flow. Current goes from location of higher potential into lower potential
When the two potentials even out, the current flow stops.
So over time, circles of people involved with electricity took a standardized direction for the movement of current and continued to develop other useful things from that. In parallel, you had the people who were researching the microscopic world. Over time, they managed to figure out that you had carriers of electrical charge and that in metals, they are usually electrons. They also realized that say in liquid solutions, you can have ions that can carry current as well. Over time, it turned out that the flow of electrons is opposite of what the macroscopic guys who were working with current defined to be the positive direction of current and that's how we got the "electron" current (blue in picture) and the "conventional" current (black in picture). Electron current in blue, conventional in black
As previously said, the macroscopic world worked up to a level without actually understanding what's going on at the low level. The result was that the discovery of the sign of charge of electrons made no significant impact on the workings of things in the big picture of electricity. So there was no pressing need to redefine the direction of current flow in traditional electrical engineering. It just turned out that our electrons move in the opposite direction of what we thought they do, but everything else is the same. So it remained that the conventional current flows from the location of higher electrical potential to the location of lower electrical potential, but actual flow of electrons is in the opposite direction. So both are actually correct.
Electricity is transition (moving) of electrons. So, What you was taught in school is right.
When an electron leaves its place, a net positive charge appears due to the positively charged protons which remain. So, If many electrons flow in a specific direction, You can consider or imagine that there are virtual positive charges flow in the opposite direction.
For example: If you have some electrons placed at node "A" and the electrons moved to node "B". First, Node "A" had less positive charges than node "B". After moving the electrons, Node "A" become more positive than node "B". So we can say that the positive charges have moved from node "B" to node "A" (the Opposite direction of electron flow).
Electrons move to create electricity. However, quantum physics makes the answer weird. Holes (the absence of an electron) yield positive charge and they behave no different from real particles, like electrons. This feature of reality is known as a quasiparticle
In a metallic crystal, like a typical metal wire for circuitry, electrons are not seen moving from atom to atom. There is a superposition of states that resembles a charge cloud. In this cloud, positive and negative charge statistically build at interface points and that's about all you really measure of what's happening inside the circuit's segments.
It's more complicated than the above description, but the point is that it truly makes no difference which way you think about it. Arc welders do care, but they are very interested in two important interface points, so they're an exception.
  • \$\begingroup\$ Actually, "holes" do behave differently - eg, PFETs have poorer performance, and as a result it has long been convention to use low side N channel switches wherever possible even to the point where people will jump through the hoops to create a floating gate drive so that they can use an N-channel device as a high side switch. \$\endgroup\$ – Chris Stratton Aug 3 '20 at 1:40
  • \$\begingroup\$ Understanding exactly what's going on in a FET is beyond even my training as an engineer. I'm not sure that p or n channel types behave differently based on holes vs electrons. It's likely related to the fundamental properties of the materials available to achieve desired dopings. I'd need a particle physicist to chime in.Regardless, it has no bearing on the perceived direction of electricity flow. \$\endgroup\$ – Somethin Somethin Aug 4 '20 at 4:14
  • \$\begingroup\$ Seems you admit you don't really understand what you posted. While holes certainly have a virtual particle-like behavior, their behavior is fundamentally less mobile than that of electrons, and this has rather serious practical implications. Please don't try to hand wave away such realities as being above your pay grade; what you said is simply false. \$\endgroup\$ – Chris Stratton Aug 4 '20 at 4:33
  • \$\begingroup\$ I don't know why you have decided this is a debate where you need to insult me, but I STRONGLY encourage you to read Wikipedia's entry on "electron mobility" where it points out the mobility of electrons or holes depends on impurity concentrations. You are confused that electron mobility is superior to holes. That's simply false and to know how a material behaves in this respect requires a first principles analysis outside almost anyone's pay grade. \$\endgroup\$ – Somethin Somethin Aug 5 '20 at 19:06
  • \$\begingroup\$ I'm afraid you are simply uninformed, most likely as a result of relying on or misinterpreting questionable sources. The undeniable reality that in available processes holes are less mobile than electrons has had immense impact on our industry, especially as FET's have come to play the dominant role in low to moderate voltage applications - if there were an easy workaround, people would have saved immense amounts of money using it. Your refusal to believe what everyone else knows won't change the facts. \$\endgroup\$ – Chris Stratton Aug 5 '20 at 19:53
